RTV CCA Battery
/ RTV CCA Battery #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
Dose anyone know what the stock battery in the RTV 900 has for a CCA rating? I can not find anything on the battery its self or in my owner manual.
/ RTV CCA Battery #2
Don't hold me to this, but I seen somewhere, that is was something like 550 cold cranking amps. Whatever it is , I do remember, it's not that much at all, that's what got my attention.
Are you haveing to replace the battery, if so, may I suggest the Omega battery. For a friend of mine replaced his with this make, and this is a really stong battery. He works the devil out of his RTV ~~~
That's what's going to be my next ~~~~
/ RTV CCA Battery #3
I didn't know Omega made utv batteries.
Optima makes an excellent battery.
/ RTV CCA Battery
No battery problems here. Its just that the winch that I want to get says that the battery has to have 500 CCA min. If I do need a new battery I would want it to be a gel cell type. Thanks for the info and help guys.
/ RTV CCA Battery #5
deerlope,
Your covered on the cca ~~
What winch are you a lookin' into ~~~~
The reason some of the companies states that about the 500 or less.
They don't you hooking on up to some sort of Mickey Mouse lawn mower battery ~~~~
/ RTV CCA Battery #6
Skipholiday ~~
You are 100% right ~~~
my mistake, I was meaning a Optima ~~~
Don't know what in the heck my brain was doing !!!!
Thanks for the correction !!!
/ RTV CCA Battery
I am looking very seriously at the Warn RT 4000 lb. Because of my tracks which make it approach 3000 lbs and I haul stuff with mine. I don't think I need to go to the 5K Ramsay. The on line company says to have at least a 500 CCA battery. I did put in a call to my Bota dealer and he came back that the RTV has a 535 CCA as stock in it.
/ RTV CCA Battery #9
If it does have a rocker switch set-up, the best place I found to install it was where the signal light swich blank is ~
Mine was a Ramsey and itstalled it there >>>
Now I had to install it up-side down for the reason of the suport bracket wouldn't go the other way for the way the dash was made. But it doesn't matter, I can read up-side down ok ~~~~ And I'm the only one running this unit !!!
/ RTV CCA Battery
I already have a rocker switch in that hole to run my amber beacon lite. I have to poly roof on it and tomorrow I am picking up some lexan to make doors for it. So will more than likely put a bank of switches up near the ceiling and move my beacon switch up there also.
/ RTV CCA Battery
Nope no snatch block yet. I very seldom ever leave my own property with it. If I ever get it stuck here I will just get my Bota tractor with the 10,500 lb logging winch on it and humpteen feet of cable.
/ RTV CCA Battery #13
To make you a secure panel for overhead. Being I also own a sign company, I had access to a .080 aluminum painted blanks. This is the same thickness as a STOP sign. Go to a local sign shop & get 'em to cut you a piece of painted aluminum and make the corners radius of 1 or 1-1/2" ~~~~ Get yourself a marine switch panel with fuses, ( ebay has 'em ***** $ 12.00) and run you a hot wire up to the switches, and then spider out from there ~~~
Get you some very fine sandpaper, and ruff up the paint on the aluminum, prime it with a Krylon quality acrylic, and paint it the KUBOTA ROPS grey color.
/ RTV CCA Battery
That is a very sharp looking panel. I have some of the road sign Alu on hand. I got an old unused directional sign from where I use to work(retire now). I plan on putting piloted lighted switches in it. My main feed wire will be # 6ga and that will also be fused or have a circuit breaker.
/ RTV CCA Battery #15
You're are ready to go then. Be sure to add yourself a few extra switches for future installments ~~~~
/ RTV CCA Battery
I don't want to get too fancy with this one because I will be trading for a new 900 now that I know how to set one up. You guys have given me so many ideas. The new will have a Curtis cab and heat. A 2 inch lift kit and 27 " tires, A turbo!!!!!!!! and more switches than you would see in an airplane.
/ RTV CCA Battery #17
being the rtv's have a nice alternator output i would put a secont battery with a battery disconnect switch in between them that way you could use the stock battery just for starting the rtv an the headlights and use the second battery for all the extra stuff. thats how i have my hpx wired up. and that second battery came in handy when i was in the woods one time and my main battery crapped out on me . the funny thing was i sat there for a few minutes trying to figure out how i was gonna get a jump start out there in the middle of nomans swampland then i remembered "hey dummy you have two batteries and there is a switch under the seat that turns the other one on" so i turned the switch and i was on my way. you can't beat the two battery system i had my stock charging system charging my stock battery and i had a toyota tercel 90 or 100 am alternator charging my marine deep cycle battery i was never in need of any power infact my hpx ran betterbecause it had all the electrical power it needed to run.
2012 Honda Crosstour Hatchback (A66738)
2012 Honda...
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A67714)
2010 INTERNATIONAL...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2020 CATERPILLAR 259D3 SKID STEER (A65056)
2020 CATERPILLAR...
2013 GMC Sierra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Sierra...
2020 Chevrolet Tahoe SUV (A66738)
2020 Chevrolet...
