Rtv 1100 speed
   / Rtv 1100 speed #11
"you can turn up the pump a bit by removing the tamper-proof cap on the pump for access and making about 1/2 to 3/4 of a turn".
Which screw and which way?
   / Rtv 1100 speed #12
I took my 1100 in to the dealer to find out why it would not go over 23 mph and they turned up the pump from 3100psi to 3200psi. They said this was max based on factory manuals. They did tell me the dealer in Colorado doing the $3000 turbo package has factory permission to go to 3800psi and still be with in warantee. My dealer is trying to get Kubota approval to do this. I'm not looking for more than about 27mph, i mainly want power because i'm in a hilly area.
To get more power Im going the turbo route like Mikeyd has done.
I have the turbo installed an ready to go.
Does anyone know if it is necessary to change the injector tips for more fuel with the turbo running aout 6 lbs of boost? If so, where can one buy these injectors.
thanks for any advice,
Chuck
   / Rtv 1100 speed #13
Chuck
I ended up getting a Workshop Shop Manual and it says you can to up to 3840 psi on the pump. I took mine back to the dealer and had them set it up to that. Still didn't make much difference though. I did find the pressure relef valve for the tied to the brakes was mis adjusted and this seemed to help power and speed a bit.
   / Rtv 1100 speed #14
Dargo said:
you can turn up the pump a bit by removing the tamper-proof cap on the pump for access and making about 1/2 to 3/4 of a turn.
Is the tamper-proof cap on top of the pump, towards the front of the pump?
   / Rtv 1100 speed #15
I'll have to look for you. It's been a while. Unfortunately I had some surgery and am laid up for a bit. I'll post when I'm able to get out and look. Sorry for the delay. Believe me, I'm not enjoying it. :eek:
   / Rtv 1100 speed #16
The Kubota rep turned my fuel control up (it was still under warranty) to get more revs but still will not get any more than 25mph so I would leave it alone. My concern was power at high altitude, 6,200 feet here and have been to 8,500' where I thought I would have to leave it for good. Kubota misrepresented the 1100 to us folks in the mountains buy selling them here, not to mention the sticking in gear issue, and would not own up to their mistake. Now I have to suffer everytime I look at the thing knowing what a costly mistake I made.
14ft Tri Axle Homemade Trailer (A57453)
14ft Tri Axle...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2011 Forest River Crusader 320RLT 36ft. T/A 5th Wheel Travel Trailer (A56859)
2011 Forest River...
INOP/NON-RUNNING 1999 Isuzu NPR-HD Cab and Chassis Truck, VIN # 4KLC4B1R5XJ001370 (A57453)
INOP/NON-RUNNING...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
