RPMs when starting up
/ RPMs when starting up #1
North585
Northern Alberta
X585/2720
Advice please as to what level of RPMs I should turn off my 2720 at, so that I'll have the right throttle amount when I start up. My tractor tends to sit for a few weeks between usage (not sure if that matters), and I want to make sure it has the right level of rpms etc. when I start it.
Thanks in advance for your help,
Keith
/ RPMs when starting up #2
Your tractor should be started and stopped with the throttle lever all the way down, engine at idle.
Thanks. That's what I'll do.
Follow up question. If the tractor is in a shop that is heated to around 40 degrees in the winter, how much time do the glow plugs need before starting up?
/ RPMs when starting up #4
About 5-8 seconds or so is all you should need, but you will be able to tell after a few times buy the way it starts.
FYI- Your machine does not have glow plugs, it's a Direct Injected engine with a heater grid in the air intake.
As always, thanks very much. Every day I learn something new...today is a bonus...two things!
/ RPMs when starting up #6
As a follow up to Kenny's answer, all engine should be started at low RPM and not "revved" until you get some oil flow going to those bearings. What airplane owners often do is "walk" the prop thru several revolutions to get some oil pumping to the bearings before they crank away. If I had my way, I'd have a dry sump system with an electric boost pump to push some oil thru all the journals before I started cranking. Guess that is being a bit **** though...
Regarding the glow plugs, on my 4400 I've never used them yet, although my machine in a garage most of the time. Even when I leave it out when it is cool I don't need the GP's. But cool is 30's-40's, we don't often get "cold" here in Maryland...!!
Wayne
That's why I was asking. Now that it's getting cooler, when i have the throttle at 1/2 or so, I get a lot of chugging and blue smoke. When it was 70 degrees out (20 degrees for my fellow Canadians!) I didnt get the chugging and blue smoke to any extent at 1/2 throttle. To your point, the owner's manual says the below, and it mentions the glow plugs as well...
6. Set the engine speed hand throttle to the 1/2-3/4 fast position.
7. Turn ignition key switch to the ON position.
8. Check indicator lamps:
Engine oil pressure light will glow.
Alternator/battery charging light will glow.
Engine glow plug light will glow for 15 seconds. Engine is now ready to start.
/ RPMs when starting up #9
I just don't believe you should have the throttle 1/2 open when starting any engine...
/ RPMs when starting up #10
Same here Kenny, common knowledge tells me starting a combustion engine at the lowest speed possible will do the lesser harm.
/ RPMs when starting up #11
I hear the "common sense" thoughts, but then I think the engineers who conceived, designed and built my tractor more than likely know a whole lot more than me about engineering and design. :D
/ RPMs when starting up #12
I hope they know more than I do if not we all need to sell and do something else.
BUT, what are the engineers trying to achieve? I suspect that controling emissions is a bigger deal than engine longevity. My 4520 with throttle down starts up at 1300 rpm and I would prefer something closer to 1000 rpm.
Steve
/ RPMs when starting up #13
With our 4320 I've found it tends to hesitate and blow a lot of smoke if started at minimum throttle when cold, seems to "catch" and go smoother at about 1/3 which I thik is what manual says. I'll usually do that so building isn't full of smoke but turn it down almost immediately.
/ RPMs when starting up #14
On both my JD 4010 (with glow plugs) and 240D Benz, these require about 1/2 throttle in really cold weather for them to start and to continue to run. Just throttle them back to about 1200-1500 rpm once they start.
Best protection for the engine on cold starts is a good 0wxx oil in the crankcase. That oil will provide instant lubrication to the valve train even down to -40 C/F.
Ralph
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
1987 INTERNATIONAL S1900 S/A BOX DUMP TRUCK (A64277)
1987 INTERNATIONAL...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
