RPM's for tractor
/ RPM's for tractor #1
MDSteve
Clements MD
Kubota 3710
RPM\'s for tractor
This is my first tractor 3710 and I was wondering what rpm range do you keep the tractor at. I am usually between 2000 and 2500. The PTO is to be run at 2500 and I wonder if I should always keep the tractor at this level even when I am using the boxblade or just moving from area to area?
Thanks
/ RPM's for tractor #2
Re: RPM\'s for tractor
To be honest I wouldn't be too concerned about it. When using non-PTO operated implements I just use judgement by feel and sound. When running a bush hog I do keep it above 2000 so the PTO speed is appropriate. Just my opinion!
/ RPM's for tractor #3
I agree with Tony - rpm is pretty flexible. Your tractor has enough power to do a lot of things at less than 2500 engine rpm. Mowing machines work a little better at full 540 pto rpm but may do a decent job at lower speed if the grass isn't too dense. At lower engine rpm, the ground speed is lower too - so if the blades are sharp, it may cut ok.
/ RPM's for tractor #4
Like the other guys said, it's flexible, and just nothing to be concerned about if you're not "lugging" the engine. I always ran tractors at the PTO speed when using a PTO powered implement, whether my finish mower, brush hog, or tiller, or my neighbor's haybine and baler, etc. However, if I was going somewhere here on my property, I usually ran mine under 2000 rpm, and while it'll be a little different for different tractors, and depends on how hard or fast you're working, it just seemed to me that 2200 was just about right for my B2710 when I was using the FEL and/or box blade.
/ RPM's for tractor #5
I have touted my opinion here before that too many tractors are being run at too high of RPM for thier given task. I like too play it by ear by matching tool speed with feed speed to achieve the most efficiency.
For loader, boxblade, brushhog, Backhoe with PTO pump, I will keep tach at 1600-2000, only with the rototiller do I approach PTO rated RPM because I have a GST that goes too slow in 3rd and too fast in fourth for tilling
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
213121 (A64276)
213121 (A64276)
UNUSED 2023 JCB S3246E ELECTIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
CATTLE HEAD GATE (A64278)
CATTLE HEAD GATE...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
