Backhoe RPM while using backhoe?
/ RPM while using backhoe? #1
Aavantaggio
Midcoast Maine
LS MT240HE FEL
What speed do you all keep your tractor at while running your BH? My manual basically says it up to the operator, higher RPM means faster movement. Anyone have a sweet spot? I don’t think pinning the RPMs is the best idea either. It’s on a MT240HE.
Thanks all.
/ RPM while using backhoe? #2
I have a different tractor. But when I am operating my backhoe, I run the engine at pto speed. No particular reason other than it's easy to remember and is high enough to provide enough hydraulic flow and pressure to the backhoe. When hooking and unhooking the backhoe, I operate the hydraulics at an idle.
In excavators, the dial gets turned up to 11 (all the way)
/ RPM while using backhoe? #3
I keep mine where the boom movement is comfortable ... not too fast to swing or move too quick. Seems like it's usually in the 1800-2200 range.
/ RPM while using backhoe? #4
I run mine slower than 540 pto speed, I like slower and gentler movements. Occasionally, I will increase rpms for hard soil that needs a bit more power, but I am not that experienced so tend to take longer and run slower.
/ RPM while using backhoe? #5
My backhoe works best for me around 2100-2200 RPM.
/ RPM while using backhoe? #6
I run at just under half of PTO speed - for me this provides a nice balance of speed and quiet.
/ RPM while using backhoe? #7
I dont like the engine noise above 2200 so I keep it below that. I dont get any more power with faster RPM and very little more speed. 2000 RPM is just about right for power, speed and quiet of engine noise.
You can run the engine any speed you like to get the control that you need.
/ RPM while using backhoe? #8
I've seen on the internet, so it must be true, right?
You don't gain power/pressure/digging force with increased RPMs. You only gain speed of movement due to increased flow rate.
Words I've gleaned from others.
/ RPM while using backhoe? #9
My pressure at the backhoe reads 1800 psi at idle and 2200 psi at 3000 rpm. 1500-2000 ish rpm's is my sweet spot for smooth and quick enough movement unless I need that little extra psi for which I goose it.
/ RPM while using backhoe? #10
Yep, I run mine at about 2100 most of the time, sometimes at 2200. I think one time at PTO speed, seemed to be just louder, no additional power. At least I did not think so....
/ RPM while using backhoe? #11
Mine seems to run the smoothest at above 2200, between 19 and 2100, a very slight vibration.
/ RPM while using backhoe? #12
1500 RPM for most backhoe work. Higher RPMs result in faster speed but cannot detect more power.
/ RPM while using backhoe? #13
I run mine at 1500-1800 most of the time. Was talking with my dealer last week, he said if I were running a new tractor with emissions it
would cause problems not to run it faster.
/ RPM while using backhoe? #14
Wow I seem to be the odd man out I only run my tractor at 1500 pretty much all the time except if I'm pushing large trees and brush then it is usually around 2000. So for me 1500 isn't too bad especially if you aren't used to running it yet. I like 1500 as I can control my movements without shaking the crap out of me or the tractor. I think I read somewhere any RPM above 1000 or 1100 you have max hydraulic pressure so at anything over 1500 I'm not gaining much other than higher fuel consumption.
/ RPM while using backhoe? #15
With these DPFs, I would run the engine fast and hot. Running these engines at lower RPM could cause more buildup in the DPF. Unless your tractor doesnt have a DPF, then probably 15-22rpm would be fine. For me, I crank 'er up get it done. Not all the way, I am not wide open, but right around the PTO rpm.
/ RPM while using backhoe? #16
Duh, I did not think about the larger HP tractors with emissions stuff. I am below the 25 HP, so no emissions system. In that case, definitely run at higher RPMs. I could see the lower RPMs and loading the engine clogging up stuff quick.
/ RPM while using backhoe? #17
My rule of thumb is if I can't do it at 1800RPM, it doesn't need doin' LOL
/ RPM while using backhoe? #19
PTO or slightly higher. Gets it done faster, keeps the regen down.
/ RPM while using backhoe? #20
"keeps the regen down"
What's "regen"?
Ain't got one!
Ain't gonna never have one either!
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
HOMEMADE FIRE PIT (A62131)
HOMEMADE FIRE PIT...
2014 Freightliner 105' Bucket Truck (A63118)
2014 Freightliner...
HUSKIE HYD HAMMER (A62131)
HUSKIE HYD HAMMER...
Peterbilt 377 Semi-Truck (A63118)
Peterbilt 377...
1986 GMC C7000 Truck, VIN # 1GDM7D1G5GV542445 (A61165)
1986 GMC C7000...
