Royal Purple question
   / Royal Purple question #1
RancherSam
Hays County, TX
Case IH JX95 4x4
Just ordered Royal Purple 10W-40 online, and putting it in my diesel truck for the first time (usually put in 15W-40, but figured 10W-40 would do since that was the one that was available ). The web page said it was for both gasoline and diesel. My question, is this true? Is there no CI indication for diesel on this type of oil?
   / Royal Purple question #2
What type of diesel truck are you putting this oil into?I would be a leary if there is no ci approval for diesel engines.I have a 2004 dodge cummins diesel and use 15w-40 or 5W-40 syn.You can also post this question on this website Bob Is The Oil Guy
   / Royal Purple question #3
On their web site, the ONLY oil Royal Purple indicates is for diesel engines is their RP Motor Oil 15w40. No need to visit oil discussion sites where they delve into the minutiae of oil. If there's no API Cx (C followed by another letter) rating on the oil it's not for diesel engines. No more complicated than that.
Whether an oil rated for diesel engines is approved for your diesel engine is found in your owners manual.
Thanks for the info guys, I'll cancel the order. btw, has anyone here put RP 15w-40 in their 6L Powerstrokes?
aw shucks, looks like it's too late to cancel, I guess I'll just eat the shipping cost and sent it back.
   / Royal Purple question #6
If you just want a good basic diesel engine oil - go to Wallyworld and get Shell Rotella-T synthetic 5W-40, available in gallon jugs around $18. This is what I use in our Cummins 5.9L (2006) and in my JD tractor. I also used it in my Jeep CRD when I had it. No problems in any of them, and runs noticeably better than dino 15W-40 in the Cummins and tractor.
If you want to spend more and maybe get more - start looking up Amsoil, TRC, and Schaeffer's options.
   / Royal Purple question #7
Rancher,
Royal Purple does make a 15-40 for diesels as stated and you should be able to pick some up at the O'Reilley's Parts stores in your neck of the woods. They are a distributor for RP. May be easier than ordering on line and you can take it back.
Take care
TPS
   / Royal Purple question #8
Sam - The P.S. is pretty particular about oil, from what the guys at the Ford Truck Forum say. Here's a thread about 15-40 15w-40 synthetic - Ford Truck Enthusiasts Forums
Check your RP and see if it has a "C_" designation. Some of the guys over there are using some form of 15-40 RP with good results. Maybe yours will work after all? Of course, a lot of them are also using Rotella "T" (which, I think, is officially a 'cult' item :rolleyes:) 5-40 with good results, too.
FWIW - my brother is running Delvac 15-40 in his.
<edit> Oops!! Just re-read, you're talking about 10 - 40, not 15-40. Duh!! Need new glasses. </edit>
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
23169 (A50324)
23169 (A50324)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
