Roundup life
/ Roundup life #1
Haneyman
John Deere 3038e
How long does Roundup stay good if mixed in a tank?
Would like to mix 20 gallons and use little at a time over 2-3 months
Thanks,Mike
/ Roundup life #2
I had some of the little gallon (I think) jugs with the sprayer on it for homeowner usage in my shed for two years. Eventually used it to kill the grass around my pool and it still worked fine.
/ Roundup life #4
It may be less effective than when fresh, but I've used your old Roundup and even to 2 year old Roundup, it worked.
/ Roundup life #6
I got a 2.5 gallon jug of knock-off Roundup from Home Depot when it was $40, so several years ago. I mixed a batch this spring and it did fine; it's kept in the shop, dark and above freezing.
No idea on mixed longevity, I have a 3 gallon sprayer and two batches will barely do what I need done.
/ Roundup life #7
Thanks,Mike
I always mix some early in the summer and use it all season. Seems to work fine.
/ Roundup life #8
What are you mixing it in? If you are doing this in a sprayer with a PTO pump, the RoundUp mix is fine but it will corrode the pump (depending on the quality of the pump). I make sure to wash and clean and oil the pump after use.
/ Roundup life
We’re mixing in a plastic spot sprayer tank with a rural king diaphragm 12 volt pump
/ Roundup life #11
What am I doing wrong?
I have never had any leftover mix in the 1.5 gallon sprayer last more than 2 weeks without getting chunky and clogging the tip.
Does it simply need shaken up more?
2011 Chevrolet Silverado 1500 Truck (A63116)
2011 Chevrolet...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63118)
2008 Ford F-250...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63118)
2011 Peterbilt 6x4...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2016 MACK CXU613...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
John Deere Z960M Zero Turn Mower (A64047)
John Deere Z960M...
