Rounded off drain plug
/ Rounded off drain plug #1,361
Got a buddy helping me out, going through our options.
Good bite, 8" wrench, need to go bigger. Couldn't find one of my bigger pipe wrenches at the time so trying again tomorrow.
Clever, are you going to use all of the methods mentioned to see where no more will be needed? :rolleyes:
Tomorrow is a bigger pipe wrench. Option after that will be either welding a nut over the plug, or cut the plug off flush and either using an extractor or drilling it out.
/ Rounded off drain plug #1,363
This is better than watching a groundhog look for his shadow. SPRING IS HERE!
/ Rounded off drain plug #1,364
Drain Plug day. I can definitely see a shadow on the picture with the wrench, so 6 more weeks before that plug is out.
/ Rounded off drain plug #1,365
/ Rounded off drain plug #1,366
Kando
If you want to remove the plug you need to turn pipe wrench over. Remember this old saying "righty tighty-lefty loosey"
/ Rounded off drain plug #1,367
Ground two flat sides on the plug to get a good bite surface.
Lower jaw was the weak link on the one and only ridgid pipewrench I broke as well. Played h3ll trying to get it warrantied.
/ Rounded off drain plug #1,368
Kando
I didnt take the picture as any indication of how it was being used. Rather just to illustrate he broke the lower jaw
/ Rounded off drain plug #1,369
The depth of the flats is bound to be short in relation to jaw width. There will be some tendency to distort the flats and cause the jaws to cam outward as high force is applied. For best possible results you should devise a hard/rigid restraint to force the jaws to be fully seated on the flats and to prevent the jaws from moving outward on the flats even the slightest amount as the serrations dig in. . . . As soon as the plug begins to turn outward you must relax the restraint a bit. And then within ~ a 1/4 turn it will become totally unneeded.​
/ Rounded off drain plug #1,370
Wondering where this thread was. My oil drain plug is starting to round off, i might need some of these suggestions...
/ Rounded off drain plug #1,371
I am going to store this entire thread!
Who knows when I might need to refer to this information in the future?
After all: I do have one tractor that is already 68 years old, so possibly in the next 30 years I might need this reference material.
In 30 years though, I'll be 108 and likely won't remember WHERE I stored it.
/ Rounded off drain plug #1,372
Kando
Details, details. When I am laying on my back I get that I mixed up too. I pretend that I am holding a pickle jar upside down and trying to open the lid to get the direction correct :eek:
Kando
Certain i'm turning in the right direction. Same direction as the other 3 loosen. Wrong direction wasn't what broke it.
/ Rounded off drain plug #1,375
That drain plug broke the pipe wrench! it is a bad muthu#$%
Kando is a complicated man - Just like Shaft.
/ Rounded off drain plug #1,376
Getting a new drainplug hasnt occurred to you?
/ Rounded off drain plug #1,379
Why, when he could start a new thread .... Rounded off Drain Plug II
We're going to need something when Kando gets that bad boy out.
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Harrell 6710 (A64119)
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
