Rought Ride
/ Rought Ride #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
I have now owned my Grand L 3560 HSTC for about 3 years. From day one.....I was dissatisfied with the way this tractor bounced me around and otherwise extremely rough riding characteristics.
Today I had allot to get done ahead of a rain coming in. ****.....but it felt like crap driving this tractor.....over even relatively smooth ground. My JD products never seemed to provide this kinda treatment. Anyone else? What gives with these tractors? I'm getting too **** old to get bounced around like this. To top it off....the suspension seat is always bottomed out with my 225 lb frame. What can be done?
/ Rought Ride #2
Have you checked your tire pressure. Could be overinflated?
/ Rought Ride #3
are your rear tires loaded? if so, check psi w/valve stem @ 12 o'clock. either way, pressure should be around 10psi. maybe 26 psi on front.
the smaller the tractor, the more bounce given small wheel base & width. how's the condition of your land? i bounce a lot w/my zero turn given feral hog damage.
fortunately, doesn't bother me. if it continues, you may have to consider a more forgiving aftermarket seat
good luck. may consider a good elastic back support in the meantime, it helps
/ Rought Ride #4
May want to consider an air ride seat
/ Rought Ride #5
Just below the front of your suspension seat - there should be a knob. It will allow you to increase tension and not bottom out so often. Check your tire pressure. My M6040 weighs 10,100# and will bounce me around when on rough terrain. It's kind of the name of the game.
/ Rought Ride #6
Almost no tractor has a suspension or shock absorbers. Problem with a loader tractor is you don't want your front tires too soft which would give you a nicer ride. Never owned one, but as I get older, I'm thinking an air ride seat for replacements, when they come due, might be in order. It is important to note though, that the tractor is experiencing the same punishment.
/ Rought Ride
I've got the seat adjusted as far as it will go. Not enough......and several others have the issue with the seat tool. It's a suspension seat....but it does not handle 200+ lols very well. I do have loaded tires (beet juice) and will check my tire pressures.
Worth a shot....thanks.
/ Rought Ride #8
Good thought. I think my manual warns about having too much liquid in them, regardless of pressure. They need a certain amount of compressible volume available.
Edit: Oops. OP didn't mention filled tires.
/ Rought Ride #9
Kubota seats are dreadful at best. My M59 has at best 3/4 inch of suspension travel, the seat is sloped forward and is slippery. Every time I hit a bump it jarrs my lower back then slides me off the front of the seat. Like my zero turn I have to wear the seatbelt or end up out of my seat.
Eventually I will cough up the couple of grand for a new grammar air ride suspension cloth seat with swivel. At least with JD you can spec nice seats along with the platinum price tag.
/ Rought Ride #10
Foggy - something might be wrong and need to be checked on your seat( tractor seat, that is). My 2009 Kubota M6040 has the OEM suspension seat. I tip the scales at 235#. I do not have the suspension knob cranked down all the way and I VERY SELDOM bottom out in really rough conditions.
A stiffer spring or an added spring to your OEM suspension seat would certainly be less expensive than a new Grammar air ride seat.
The one thing that worries me. I've often thought about installing an air ride seat. With an air ride seat the "trip" would certainly be a lot easier on me. However, it would not be transmitting the true conditions - seat of the pants feeling - back to me. Many times it's that - seat of the pants feeling - that will let me know it's time to slow down and make the trip a tad less rough on the equipment also.
/ Rought Ride #11
Liquid ballast will make for a rough ride, especially with small tires.
SDT
/ Rought Ride #12
Just a thought, I am running turf tires now which is a switch from the r4s I used to have. Ride is much softer. I noticed there are new radials that appear to be a mixup of the turf and the r4s. Maybe a better ride?
/ Rought Ride #13
I agree about checking the rear tire pressure. My tractor was delivered with beet juice in the rears. Pressure was WAY too high from the dealership. I aired down until my tires were using the full contact area of the tire cleat with my heaviest implement on the 3PH when parked on concrete. Improved the ride 100%. I also normally keep my heavy Gannon box blade on the rear; the added weight keeps the tractor from bouncing as much, and the ballast is welcome when heavy lifting with the FEL too. I rarely bottom the seat out now, but I sure was before I deflated those tires. I've found the same is true on my zero-turn and UTV; rides like crap when the tires are brick-hard. I like to see a little bit of "pooch" on the bottom side of any tire. It not only improves ride quality, but increases your contact area with the ground, improving traction. Going too low on front tractor tires can cause you to roll the tire off the rim with a heavy load on the FEL though. Proceed with caution if you're lowering pressure in the fronts. Good luck!
/ Rought Ride #14
oosik
May I ask what type weights you've added to get your M6040 to over 10,000? My M7040 MFWD with FEL & cast rear wheels with liquid ballast in rear tires only weights 8800#s. I agree tire pressure affects type of ride offered.
Thanks,Jim
/ Rought Ride #15
oosik
Thanks,Jim
About what my M9000 cab tractor weighs as well (cast centers with the FEL on). My M9000 open station weighs about 1000 pounds less..
Tractors in general ride rough unless they have suspension which you can get but will be in a very large tractor like a Fast Trak or a Fendt Vario.
Kubota's have notoriously poor seats and suspension. My cab unit has a Grammer air ride swivel. It's fine. My open station had a Kubota vinyl suspension seat, it left one night and was replaced with a cordura covered high back seat with K&M suspension. Much better. I dislike vinyl seats anyway. Seats and seat bases are all ISO today so mounting is a snap but to go air ride, you'll need a power hookup for the compressor.
I'd say the op needs to go on a diet possibly.....:D
/ Rought Ride #16
Those seats are usually from a common vendor like Grammar. Also see optional seats with other brands.
Mine are not dreadful, they air air ride seats made by grammar not Kubota anyway.
/ Rought Ride #17
simple fact. compact tractors ride rough due to short & narrow wheel bases. sure you can spend thousands on air ride seats & radials that might help a bit. i'd rather put that into equipment
test drives on the dealer parking lot vs field just don't represent the ride well & the dealers should mention that. just the nature of the smaller machine.
even w/feral hog damaged fields, my M series tractor is smooth (for me)...having no physical anomalies for me also helps. the factory seat works just fine
wearing a good elastic back support helps a lot when i use my zero turn.
hope the OP can find a good solution to the uncomfortable ride, best regards
/ Rought Ride #18
Tx Jim - five years ago - when I got my grapple I drove the tractor into the ADM( Archer Daniels Midland) grain scales. The weight was 10,090# - +/- 20#. I have an 820# grapple on the FEL - 1550# of RimGuard in the rear tires - a 1000+# Rhino rear blade on the 3-point. That weight does not include me nor the later added sun shade.
This had better be correct or a whole lot of farmers in our area might be getting the shaft.
/ Rought Ride #19
This is the problem. Tire pressure will only have a small effect compared to the suspension seat not suspending.
If the seat's weight adjustment is as high as it will go and it's still bottomed out, buy a better seat.
/ Rought Ride
Have been away from my land since posting about this. First thing I will do is check the rear air pressure. I do know that reduced pressures can soften the ride.....just like the ride in my jeep on rough ground.
Seems to me I had read that someone came up with an air "bladder" that helped beef up the seat suspension. Anyone hear of such a thing? I gotta find some solution to this. I like the tractor in so many ways.....but the ride sucks. I do not intend to spend on a seat upgrade.....I simply dont put in that kind of hours.
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
2025 CATERPILLAR 285 SKID STEER (A65056)
2025 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
