Mowing Rough vs. Finish MMM Differences
   / Rough vs. Finish MMM Differences #1
MoreCowbell
Clayton, NC
Kubota BX2350
I know there are other posts on the rough vs. finish mower topic, but this is a different twist. Anyway, here it goes ...
I'm starting to regret buying the 60" rough MMM with my new BX this past spring. I should have gotten the finish cut model since I'm just cutting a regular lawn - no heavy brush. The rough model just doesn't cut as nicely as my old Craftsman riding mower (which I just sold). :(
Anyway, I'm trying to figure out what exactly is the design differences between the two types so that maybe I can make a mod or two to get mine cutting nicer. Based on pictues in the sales brochure and owner's manual it seems like: 1) the baffles on the finish cut MMM surround each blade more completely, and 2) the top of the front section of the rough cut MMM is raised (I assume to allow more flow from the blades to the discharge chute).
Does anyone know of other differences between these two Kubota models? If this is it, I may consider fabbing a supplemental baffle to get a better cut. Thanks.
   / Rough vs. Finish MMM Differences #2
Anyway, I'm trying to figure out what exactly is the design differences between the two types so that maybe I can make a mod or two to get mine cutting nicer. Based on pictures in the sales brochure and owner's manual it seems like: 1) the baffles on the finish cut MMM surround each blade more completely, and 2) the top of the front section of the rough cut MMM is raised (I assume to allow more flow from the blades to the discharge chute).
This is confusing to me as I thought all MMM's on a BX were finish cut mowers and not rough cut. Now if you are confusing this with the Fine Cut Decks that are offered -Which I think you are. I am not familiar with the fine cut as most dealers steer folks away from them. You don't list the problem that you are having but proper deck set-up is most likely to cure your concern as BX Kubota's are designed primarily as grass cutting machines.
   / Rough vs. Finish MMM Differences #3
Wow, this is a new one to me. Like Flatlander said; I've never heard of a rough cut MMM.
Maybe all you need is higher vac blades on the deck you have now. If the MMM you have now is in fact for rough cutting that means the blades are made to cut thicker brush and taller grass and blades made for cutting rough growth usually are zero to very little vacuum (in other words they have no upturn to the back edge of the blade). A "regular" mower deck on a lawn tractor has blades with quite a lot of vacuum edge built in. This causes the grass to get pulled up straight from the ground and that makes a much more even cut. You might check if higher vac blades are made for the deck you have.
   / Rough vs. Finish MMM Differences #4
Are you cutting at the full rated PTO RPM?
   / Rough vs. Finish MMM Differences #5
I have owned two BX's with "regular cut" 60" MMM decks and both have given as good of finish as my previous pure lawn mowers including a John Deere 425. A "fine cut" deck is offered, but I have rarely seen them addressed on the forums.
You might want to check with mow4fun as he has a 54" "fine cut" deck.
   / Rough vs. Finish MMM Differences #6
I also have a standard cut 54"...Cuts better than anything else I've ever owned.
The dealer told me I didn't need the fine cut.
What's the model number of your deck?
   / Rough vs. Finish MMM Differences #7
I would have to agree with the boy's above that that is a good cutting deck you have!
To high of ground speed and too low of engine speed could be the culprit.
   / Rough vs. Finish MMM Differences #8
Examine the blades - you might want to sharpen them up.
FWIW, the blades on the 72" MMM for our B2910 had probably a 1/16" or better flat on the edge when new (safety, mfg. liability, etc.)
   / Rough vs. Finish MMM Differences #9
Well, OP ain't posting. No more cowbell :(
There is no such thing as a "rough cut" MMM, nor has he described how his cut is inferior.
But I wonder how much attention he has paid to the mower setup. I have tried two methods, both are hit or miss.
(And once I get it set perfect, I invariably slam it into something)
Wow - I really botched my post. My terminology was all over the place. You guys are right - I have the standard cut deck and the one that I was wondering about is the "fine" cut. Sorry for the confusion.
I make sure to cut at about 3050 RPMs which I believe results in the proper PTO speed. My usual ground speed is about 3/4 speed in low gear so I don't think I'm going too fast. I've had gators on it for a while now (mounted right-side up).
I took another look at what I'm getting and it may be the result of having a lot of varying terrain. Maybe 60" is just too wide for having so many dips and peaks.
Anyway, thanks for all the input. I really appreciate it.
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2014 Ford F-150...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2002 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2002 Ford F-250...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
