rough running 3020
/ rough running 3020 #1
PRuss
Peru, KS
3020 John Deere, D17 Allis Chalmers, IHC 504
I have a mid 60's 3020 gassser that is hard starting, burns rich and is running really rough and even rougher under a load. Any ideas where to start.
Thanks
/ rough running 3020 #2
Sounds like you need to rebuild the carb.Did you run Ethanol blend gas in it?That stuff is tough on older equipment.
/ rough running 3020 #3
I have found Pertronix points replacement modules to be a good way to eliminate points. Motors start and run a whole lot better. 1145A or 91145A are the part numbers for a 3020. For good prices just google the part number. This is in addition to what nybirdman has said.
My neighbor thinks it may have a bad valve, but the exhaust does not suck inward at all which makes me think not. My wife got me the last gas so there is a possibility of some ethanol. That's it blame it on the wife!
/ rough running 3020 #5
Agree it sounds like carburetor. May be float bad or float valve leaking. Is this a tractor you have had a while? Has it always run rough? Has it been tuned up lately? I don't recommend Champion plugs in these engines. Have not had good luck with those. I usually use Autolite with good results. If still using points, try napa points and condensor. They are superior to what Deere sells these days.
/ rough running 3020 #6
Check the air filter too. On friends tractor that would barely run (after 18 months of sitting) he found the air filter housing completely filled with a mouse nest.
Thanks to all, this will definitely give me a place to start...Happy Independence day!
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A67737)
2024 DODGE RAM...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
