Rough cut mower size
   / Rough cut mower size #1
erda
Alberta
Kubota B2601
Just wondering if anyone makes a 54 inch rough cut? 48 is smaller than the track, and 60 might be too much mower for a 20 pto hp tractor.
   / Rough cut mower size #2
Yep - I know WOODS makes one - Good brand but a little pricey sometimes
Product Details
Just google 54" brush hog and you will get some more info. They are mainly light duty (which is what you want with 20hp PTO) units but there are a few out there.
   / Rough cut mower size #3
Have you tried running the 48 off center? You're only gaining 6" with a 54 and that is 3" on each side. You should be able to easily offset your 48" by 3" to one side or the other and get it to fully cover the tires on one side. Won't cut down the mowing time (of course 6" extra won't by much at all either) but should be easier to line your rows up.
   / Rough cut mower size #4
Get a 60 inch. I ran a 60 inch with a 750 JD. Would work well in most cases.
If the mowing got to heavy and lugging the engine down I just take 2/3 of a swath.
   / Rough cut mower size #6
I run the Woods 54" on my Kubota 2620-a 20hp tractor- and it perfect for the work I do. Most of my cutting are fields that are mowed 2-3 times a year, but I have also been reclaiming some areas on our hunting lease that have not been cut in 8-10 years
Will
Thanks for the info!
Just wondering, how "finished" of a cut does a rough cut mower give? Not looking for golf green manicure, but something passable for acreage living.
   / Rough cut mower size #8
Mine does not leave a real nice cut - I run a 6' medium duty and don't really keep up on sharpening my blades as I use it to clear woods and heavy brush frequently. Some say if you keep a sharp edge on the blade it will do a much better job.
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
1272 (A50490)
1272 (A50490)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
BLAST SHIELD (A50854)
