rototiller
/ rototiller #1
scottth
hello i am looking at a ccm mr175 rototiller for my iseki tractor can somebody tell me how deep it will till and how easy it is to adjust and how you do it does it do good in clay soil it seams to be a nicely built tiller thanks for any info
scott
/ rototiller #2
If you buy a very wide tiller, bring lots of power. I have a 72" heavy built really nice tiller that will till to about 9" deep. However, it takes every bit of 50hp PTO power to do that in my hard packed heavy clay soil. Unless you have well over 50 hp PTO power, I wouldn't worry too much about how deep the tiller will till. It will likely till deeper than you can turn it. As the saying goes, don't ask me how I know that. /forums/images/graemlins/grin.gif
/ rototiller #3
What is the horsepower rating on your tractor? And how wide is that tiller? Personally, I have a 29hp tractor, and it handles a 5ft tiller great! Also, you will love the tiller. There are so many uses for it. One piece of advice. Sometimes, when hitting real hard soil, the tiller can bounce or "hop" a bit. When this happens, it can loosen bolts and nuts real quick. Just watch it close, and the bolts and nuts that come loose, add lockwashers to them. It will save a lot of headache and lost bolts. Good luck!
/ rototiller #4
ALso forgot to mention, if you want to see some good pics of how impressive a rototiller is, go to the photo section, and on like the 3rd page or so, you will see my post named "Pond Project and some other stuff". Look at the pictures there towards the end of the post and you can look at what it will do to rock hard clay.
-Brad
/ rototiller #5
I've noticed that on my 52" tiller, if I try to penetrate hard soil deeply in one pass, my tiller hops and bangs around a lot. But if I set it for about 2" depth, it is much smoother. Then on subsequent passes, the skid shoes sink and the tiller is cutting 4" or so.
Think it has a lot to do with angle of attack, whatever that is!
Ron
/ rototiller #6
I recently bought the same unit for my NH TC35 and the tractor works fine with it. If anyone is interested, I have an Agri-tec 5ft tiller for sale. Works great, but was too light for the TC35. had it behind a 1520 and was a good match.
/ rototiller
hello all thanks for the info my tractor is a 40 hp tractor with 32 hp to the pto this rototiller is 66 inches i think we played with it and it seams to till around 5 inches deep i sure would have thought it would till atleast 8 inches in the garden it seams to be a well built machine but not happy with the depth it will till i guess i will have to do some custom work on it so i can get it to work like i want any ideas on how to get it to till at a better depth thank you scott
/ rototiller #8
5in depth is pretty good for 1 pass in previously undisturbed soil 2 or three passes should get you to 8in.
If you have a moldboard plow use it first and you will get 8in first pass
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Fire Ring (A65640)
Fire Ring (A65640)
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2017 Ford F-250 Pickup Truck (A64556)
2017 Ford F-250...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
