Rototiller PTO vs stand alone
   / Rototiller PTO vs stand alone #1
rgarry
John Deere 3032
Hi, Have a JD 3032e and have about 1/3 of an acre that we are going to plant (has irrigation under it (8-12"). Trying to figure out if I am better off with a stand alone rototiller which seems a little bit easier to adjust vs a 4 ft PTO based rototiller. The areas does have some trees and thus maneuvering around with the tractor takes some time. I was thinking that a stand alone unit will allow me to avoid sprinkler heads and set it at 6" with good precision. Obviously, it will be harder to upscale and I know that many of you use a rototiller for other uses. I do have a box blade which I use along with the brush hog to keep the trails open. The property is 62 acres. Thanks for any advice.
Ron
   / Rototiller PTO vs stand alone #2
If you have a shallow sprinkler system in place then you don't want 6 inch till depth. It would take multiple passes and too difficult to control depth precisely. Just what are you planning that requires the till depth?
   / Rototiller PTO vs stand alone #3
I have been very happy with stand alone counter rotating rear tine tillers, also less chance of damaging your irrigation pipes. I used a MTD with no reverse for 30 years until it wore out, replaced with a Troy Bilt with reverse. If I had known how nice a reverse gear was I would have traded much sooner, much less muscle required and very maneuverable.
   / Rototiller PTO vs stand alone #4
I've used both stand alone and 3pt. I'd go 3pt all the way. Currently use a 5ft KingKutter. They do an excellent job. Because of the weight of the tractor, they won't skip or throw you around when you hit roots, rocks or other hard stuff. Get a quality one and it'll till about anything you give it. Once I was doing the maintenance on mine and found 2ft piece of 3/8" rebar wound around the shaft/tines. :eek: I never knew I hit it. For the depth, just set the depth skids as deep/shallow as you want. You'll get a very consistent seedbed.
   / Rototiller PTO vs stand alone #5
If " 1/3 of an acre to plant"mean's once and done,I'd rent a walk behind rear tine. If you are planting 1/3 of an acre garden,I'd buy a r walk behind rear tine so as to cultivate between rows during growing season. A quility pto driven tiller has means of controling depth but I question the need for only 1/3 acre. You might find other use for a pto but you will find far more use for a rear tine. If you are planting a food plot or cover crop,rippers on your box blade will do pretty good job and depth is easy to control.
My neighbor didn't buy either ,he borrow's mine. :laughing:
   / Rototiller PTO vs stand alone #6
"My neighbor didn't buy either, he borrow's mine." ...ain't that the truth! And something always breaks when they borrow it.
Good point you make about cultivating between rows of a garden. A walk behind would be the way to go there.
   / Rototiller PTO vs stand alone #7
neighbor
But the worest doen't come until while watching you repair it, neighbor tell's other neighbor "that wouldn't have happened had you bought higher quility equipment".:censored:
   / Rototiller PTO vs stand alone #8
neighbor
Where I come from if it breaks while you are using it you repair it.
   / Rototiller PTO vs stand alone #9
Ron
I have both a Troy Bilt and a 5' King Kutter.
I bought the King Kutter ten+ years ago.
The troy Bilt has been sitting in a corner of the barn ever since.
   / Rototiller PTO vs stand alone #10
At my place, mechanically operating tools are NOT LOANED OUT, and hand tools are very rarely loaned (they never come back)!
I will volunteer to do the work for you, if/when I have the time.
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
John Deere 4820 Forklift (A57453)
John Deere 4820...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2020 Chevrolet Tahoe SUV (A55973)
2020 Chevrolet...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
