Hi, Have a JD 3032e and have about 1/3 of an acre that we are going to plant (has irrigation under it (8-12"). Trying to figure out if I am better off with a stand alone rototiller which seems a little bit easier to adjust vs a 4 ft PTO based rototiller. The areas does have some trees and thus maneuvering around with the tractor takes some time. I was thinking that a stand alone unit will allow me to avoid sprinkler heads and set it at 6" with good precision. Obviously, it will be harder to upscale and I know that many of you use a rototiller for other uses. I do have a box blade which I use along with the brush hog to keep the trails open. The property is 62 acres. Thanks for any advice.
Ron
Ron
