Rototiller for DK40SE HST
   / Rototiller for DK40SE HST #1
chasemech
CONN
Ford 1520, Kioti DK40SEHST
Can my DK40SE HST handle a King Kutter 7' Gear Driven Tiller TG-84-YK. I need the 84" to cover my tracks (Turf Tires).
   / Rototiller for DK40SE HST #2
The TG84 should work just fine with your tractor. The only time you could notice strain would be with new/difficult ground that hasn't been plowed or torn up prior to tilling.
   / Rototiller for DK40SE HST #3
I had a 6' tiller on my 40 horse and I didnt strain the tractor one bit,so I'm positive you will have no trouble with the 84" frankly that's what i would have bought if it was available at the time.
Brian
   / Rototiller for DK40SE HST #4
But....you only need to worry about covering your tracks if you till in reverse;)
I have a 5'....no problems at all.
   / Rototiller for DK40SE HST #6
Only if your tilling 1 strip
No, till a row, move over for a slight overlap, back up, drop the tiller and till another row...repeat = no tire tracks.
Oh, yes I forgot, offset your tiller to one side so the overlap side is covered.
   / Rototiller for DK40SE HST #7
Chasemech,
Go for it! You won't have any problems w/ the 84" KKII! You'll be getting a great unit!! I use a 72" and its awesome!!!!
Post some action pics, pls...:dance1:
   / Rototiller for DK40SE HST #8
You will be fine with that tiller.coobie
JOHN DEERE HAY CUTTER (A58214)
JOHN DEERE HAY...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
NEW Long Forks (A59000)
NEW Long Forks...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
