Rotory mower vs chunk of steel
   / Rotory mower vs chunk of steel #1
Rio_Grande
Platinum Member
I dont recomend it!! Looked like an old well head that was no longer in use just above ground level. Tore the crap out of my blade edges. Guess I will be doing some grinding. try and get them cutting again. The end 3 inches looks like a serrated knife. In the mean time I will run the mower the other way. I have a brand new edge on that side.
This brought some concern to mind. If you were mowing like this and struck something valuble who does that fall on. Initally I want to say me and my inshurance, but when I bid jobs I ask the owners where utilites are and to identify anything sticking up that would disagree with a mower.
What do you think?
   / Rotory mower vs chunk of steel #2
You could get the land owner to always sign a release holding them responsible if something of value is destroyed. Kind of like a "rock" clause in a contract when excavating is being done.
Wife called the lady our business uses for a Attorney and asked her to write something up. Should have it by end of the week.
I started on the blades today. I only had a few minuets but without taking alot of metal off they are toast. I will dress them where they will cut and just use that direction for unknown stuff save the good edge.
I am having a problem with my skid steer not wanting to run continuous the other direction. If I hold the button down it works but when i let up it slams to a stop. The settings are the same when the other side is running. I have noticed a female quick connect that dosent seal right and i can turn the blades and oil just comes out. I wonder if that quick connect has an issue that is causing a the skid steer to not want to lock into detent mode that direction.
   / Rotory mower vs chunk of steel #4
Sounds like your pressure relief/check valve that lets the blade coast down is only letting the blade spin down in one direction. I would bet that if you swapped lines where they go into the motor your problems would go away.
Aaron Z
Thanks Aron, I know one of my ends was bad, I got a replacement and havent had a chance to swap it out yet. The one that came on the mower was stuck open internaly. I will give your idea a try.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2020 Chevrolet Tahoe Multipurpose Vehicle (MPV) (A52377)
2020 Chevrolet...
2025 CFG Industrial QK20R (A50123)
2025 CFG...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
