Rotary Cutter Roto tiller
/ Roto tiller #1
nesttun
Eaton Rapids, Mich
Ford Jubilee
Does anybody know if you can run a roto tiller on a Ford Jubilee. Or is it moving so fast, not a chance.
/ Roto tiller #2
I do a lot of rototilling and I use low range with HST so I control speed as needed not sure what your machine has a far as speed but you have to keep rpm's up to operate tiller and you would need to be in a low gear that would not pull tiller to fast with that eng speed.
/ Roto tiller #3
I used a tiller on my Jubilee for several tears till I got different tractors. I was told it wouldn't work but it was fine. It was a little fast I had to be in 1st gear 2nd was too fast period but you will have to go over it several times to chew it up better because of going a little faster.
This just how it worked for me. I also used the same tiller on the 841 lots more power but still the same speed, of course neither one of them had an independent PTO so if I stopped I always picked the tiller up because well because it stopped.
/ Roto tiller #4
I know this post is 3 years old but to the original poster- what width was the tiller on the Jubilee? And how many HP or PTO HP is a Jubilee?
Thanks- Oldstuff
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
