Roto-tiller or disc harrow
/ Roto-tiller or disc harrow #1
mgboddy
Burnt Prairie Illinois
John Deere 5075E
My 82 year-old uncle retired from farming last summer and gave me his JD 5075E 4WD utility tractor with a 540M loader. I want to use it for food plotting about 12 total acres in about 7 or 8 different plots on 376 acres. Each plot is 1-2 acres.
My question is would a 60-72" rototiller be a better tillage choice or a 4-gang disc harrow. I will follow either with a cultipacker prior to broadcast seeding. The plots have been cleared of trees and brush but there are a couple of stumps in most of the plots, ground to about 4" below surface. The stumps are flagged so I can avoid them if needed.
/ Roto-tiller or disc harrow #2
Welcome to TBN - mgboddy. Either implement will take a good deal of time to prepare 7 or 8 - one acre + plots. I would prefer the rototiller. Are you certain a 72" rototiller is wide enough.
All things being equal - the disk harrow will be faster if it does the job like you want.
/ Roto-tiller or disc harrow #3
The tiller is really nice and I love mine but I am careful where I use it. I don't want too be hitting anything but dirt. I use a chisel plow to break ground up good. That followed by the cultipacker should work good for food plots.
/ Roto-tiller or disc harrow #4
Depends if you are trying to break sod of not. Guessing if you've cleared trees there isn't a ton of grass.
If the disc plates are new and sharp you might have less aggravation then powered tines of a rototiller with roots and stumps.
/ Roto-tiller or disc harrow #5
John Deere 5075E​
John Deere 5075E Dimensions
Wheelbase:80.7 inches
204 cm
Length:137.8 inches
350 cm
Width:57.3 inches
145 cm (axle flange)
2WD Clearance (front axle):18.8 inches
47 cm
4WD Clearance (front axle):13.4 inches
34 cm
Front axle:Flange axle: 64.6 inch length
1640 mm
Rear axle:Flange axle: 57.5 inch length
1460 mm
Front tread:56 to 80 inches
142 to 203 cm
Rear tread:55.8 to 71.7 inches
141 to 182 cm
John Deere 5075E Weight
2WD Shipping:4,634 lbs
2101 kg
4WD Shipping:5,070 lbs
2299 kg
4WD Operating:5,475 lbs
2483 kg
I recommend a Disc Harrow with 22" diameter pans, either 72" or 84" wide, depending on how wide tractor rear tires are set. A Disc Harrow with 9" pan spacing on the front gangs and 7-1/2" spacing on the rear gangs, as produced by Monroe Tufline and Dirt Dog, would be ideal.
I will follow with a cultipacker prior to broadcast seeding.
Press the seed firmly into the soil by cultipacking AFTER seeding.
Food plot seeds are generally eager germinators.
/ Roto-tiller or disc harrow #6
Hands down a tiller!
Providing you don't buy a cheapo tiller that works too slow or that you won't be happy with, later.
SR
/ Roto-tiller or disc harrow #7
For the job at hand a Tiller would be an ideal implement. It works well in uncultivated ground and probably goes deeper than a disk.
For the first & second year you plots may not be as productive as you wish But as the soil gets conditioned growth increases.
Culti pack after seeding.
/ Roto-tiller or disc harrow #8
I assume you are broadcasting cover crops since food crops are generally a row crop?? Or are they food crops for live stock?
A tiller is great, but farmers have been working ground with a plow and disc for many years so that obviously works. The disc is cheaper to buy and maintain and faster to use.
I'd put the money into improving the soil instead of the tiller. Good loose, well nourished soil will work up just fine with a disc.
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2020 CATERPILLAR D6 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
