Rotella 5W-40 Synthetic in John Deere GT245?
   / Rotella 5W-40 Synthetic in John Deere GT245? #1
WSJ
Western NY & Northwestern PA
Kioti CK25
I just changed oil in my Kioti CK25 and used the Rotella synthetic for the first time. I was impressed with the immediate difference in the ease with which it turned over, with temps in the 20's, compared to the standard Rotella 15W-40.
So since I bought 2 gallons and have a couple quarts left over, and I have a snow blower on the GT245 garden tractor (20 hp. air-cooled kawasaki, pressurized) that I'll be using all winter, is there any reason not to change it over to synthetic as well?
Thanks. -WSJ
   / Rotella 5W-40 Synthetic in John Deere GT245? #2
Simple test - If it meets or exceeds the API requirements listed in the owners manual, no, there are no issues.
   / Rotella 5W-40 Synthetic in John Deere GT245? #3
I run Rottella T 5w-40 synthetic in both my tractors.
I also use the same oil in everything else. Our car, truck, garden tractors, push mowers, walk behind tiller, generator, Etc.Etc.
   / Rotella 5W-40 Synthetic in John Deere GT245? #4
going from any 15w-40 to any 5w-40 will show/feel big changes.
   / Rotella 5W-40 Synthetic in John Deere GT245? #5
Thanks. -WSJ
That gas engine probably specs 5W30 or 10W30. It would be OK if meeting the API requirement, But not the best choice for maximum fuel economy. A lot of gas engine oils have friction modifiers that the Rotella 5W40 may not have.
Hmmm. This oil thing is addictive, even if you're ignorant like me. I guess maybe I'll stick with my old stand-by Castrol for the JD and save the synthetic for the Kioti. I believe I will try the synthetic in my cheapie Craftsman air compressor.
Thanks all for the insight. -WSJ
   / Rotella 5W-40 Synthetic in John Deere GT245? #7
WSJ,
What are you afraid of?
I use Mobil 1 in ALL my engines. Most use 5w30, including my JD diesel. My old Benz specs 10w40; so, I try to use 5w40 Mobil 1 when I can get it or blend 5w30 and 15w50 50/50 available all the time. In the old Gravely that I no longer have, I'd put either 15w50 or 0w40 (when I could get it). It actually quit using oil after the 2nd or 3rd change on Mobil 1.
By the way, Castrol doesn't make a drop of oil. They had been buying from Exxon. They do develop their own additive pack.
Ralph
   / Rotella 5W-40 Synthetic in John Deere GT245? #8
I have been using Mobil 1 in all my vehicles since 1983 and will continue to do so. I plan on changing over to Rotella 5W-40 synthetic on my B7800 when I break the engine in. I also use Mobil 1 in all my other 4 cycle engines, i.e., lawn blower, snow blower, 1989 Wheelhorse, etc.
   / Rotella 5W-40 Synthetic in John Deere GT245? #9
I ran Mobil 1 5W-30 in my old John Deere GT225 (15hp single cylinder Kohler) with great results. I would think you would see (hear) a quieter and cooler running engine with the synthetic.
   / Rotella 5W-40 Synthetic in John Deere GT245? #10
5W-40 Rotella in my B3030..I like the stuff myself
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
Electric Mobility Scooter (A54815)
Electric Mobility...
Lincoln Electric Invertec V275-S Welding Machine (A53117)
Lincoln Electric...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2013 Ford F150 Pickup Truck (A53422)
2013 Ford F150...
