Rotella 5W-40 Synthetic in John Deere GT245?
   / Rotella 5W-40 Synthetic in John Deere GT245? #1
WSJ
Western NY & Northwestern PA
Kioti CK25
I just changed oil in my Kioti CK25 and used the Rotella synthetic for the first time. I was impressed with the immediate difference in the ease with which it turned over, with temps in the 20's, compared to the standard Rotella 15W-40.
So since I bought 2 gallons and have a couple quarts left over, and I have a snow blower on the GT245 garden tractor (20 hp. air-cooled kawasaki, pressurized) that I'll be using all winter, is there any reason not to change it over to synthetic as well?
Thanks. -WSJ
   / Rotella 5W-40 Synthetic in John Deere GT245? #2
Simple test - If it meets or exceeds the API requirements listed in the owners manual, no, there are no issues.
   / Rotella 5W-40 Synthetic in John Deere GT245? #3
I run Rottella T 5w-40 synthetic in both my tractors.
I also use the same oil in everything else. Our car, truck, garden tractors, push mowers, walk behind tiller, generator, Etc.Etc.
   / Rotella 5W-40 Synthetic in John Deere GT245? #4
going from any 15w-40 to any 5w-40 will show/feel big changes.
   / Rotella 5W-40 Synthetic in John Deere GT245? #5
Thanks. -WSJ
That gas engine probably specs 5W30 or 10W30. It would be OK if meeting the API requirement, But not the best choice for maximum fuel economy. A lot of gas engine oils have friction modifiers that the Rotella 5W40 may not have.
Hmmm. This oil thing is addictive, even if you're ignorant like me. I guess maybe I'll stick with my old stand-by Castrol for the JD and save the synthetic for the Kioti. I believe I will try the synthetic in my cheapie Craftsman air compressor.
Thanks all for the insight. -WSJ
   / Rotella 5W-40 Synthetic in John Deere GT245? #7
WSJ,
What are you afraid of?
I use Mobil 1 in ALL my engines. Most use 5w30, including my JD diesel. My old Benz specs 10w40; so, I try to use 5w40 Mobil 1 when I can get it or blend 5w30 and 15w50 50/50 available all the time. In the old Gravely that I no longer have, I'd put either 15w50 or 0w40 (when I could get it). It actually quit using oil after the 2nd or 3rd change on Mobil 1.
By the way, Castrol doesn't make a drop of oil. They had been buying from Exxon. They do develop their own additive pack.
Ralph
   / Rotella 5W-40 Synthetic in John Deere GT245? #8
I have been using Mobil 1 in all my vehicles since 1983 and will continue to do so. I plan on changing over to Rotella 5W-40 synthetic on my B7800 when I break the engine in. I also use Mobil 1 in all my other 4 cycle engines, i.e., lawn blower, snow blower, 1989 Wheelhorse, etc.
   / Rotella 5W-40 Synthetic in John Deere GT245? #9
I ran Mobil 1 5W-30 in my old John Deere GT225 (15hp single cylinder Kohler) with great results. I would think you would see (hear) a quieter and cooler running engine with the synthetic.
   / Rotella 5W-40 Synthetic in John Deere GT245? #10
5W-40 Rotella in my B3030..I like the stuff myself
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
