ROTATILLER- FORWARD OR REVERSE
/ ROTATILLER- FORWARD OR REVERSE #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I am considering buying a tiller for food plots. The soil is rocky, but I will till only top several inches to avoid jamming the tiller. The walk behind kubota tiller I use for home garden can be used with tines running forward or reverse. Reverse does a better job of breaking up ground. This machine unfortunately is not big enough for 2 acre food plots. Can tillers run off PTO be run in reverse rotation? For that matter, can PTO rotation be reversed?
/ ROTATILLER- FORWARD OR REVERSE #2
You can purchase either a forward or reverse tine tiller. Here is a recent thread on a reverse tiller. Click Here
I am not aware of PTO's that can be reversed. There may be gear box that can be added to reverse direction. On my tiller the PTO shaft is only 26" long. Not much room to put an additional gear box.
1995 Freightliner FL70 S/A Dump Truck (A64556)
1995 Freightliner...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
