rotary mower
   / rotary mower #2
Well Welcome. What are you looking to cut, grass, saplings, weeds? Are you looking for a finished type cut or a rough cut? Please fill out your profile so TBN members can answer your questions based on where you live.
DevilDog
   / rotary mower #3
If you are looking for a rotary cutter Hawkline makes what seems to be a good one. They are suppose to be made here in the USA and the price is about 30% less than a "name" brand one. I bought one last year, not a very pretty looking thing, it does look durable. I have not used mine yet due to I bought it over the winter due a good deal I found.
http://www.gohawkline.com/pdf/4.09_HawklineCatalog.pdf
   / rotary mower #4
As a follow up to devildog...
Are you looking to mow a lawn (using a rear finishing mower) or a field (using a rotary cutter)?
Since I think you meant rotary cutter, the main thing is to size the cutter to your Kubota (both the HP requirements and the weight of the implement). You would best be served by a 48" cutter, IMO.
The Kubota site or your manual should have some information about sizing implements to the tractor.
   / rotary mower #5
I am pretty sure your manual recommends a rotary cutter of no more than 42". The BX manuals do tend to be a bit conservative though.
I own a BX2660, but have no experience with the 1800.
   / rotary mower #6
Since TripleR brought up the 42" cutter...is the BX1800 a Category 0 or a Category 1(for rigging implements to the 3PH)?
1aberg1, you'll need to know which your BX1800 is before buying an implement.
   / rotary mower #7
I am "pretty sure" the early BX models were "limited category 1" while the later ones are category one.
I believe TSC XB equipment is aimed at them. Woods and Land Pride also offer models for the smaller tractors. I wasn't really sure on mine, so I talked to my dealer.
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2019 ALLMAND V-SERIES LIGHT TOWER (A58216)
2019 ALLMAND...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
