Rotary mower gearbox input seal. How often gear oil change?
   / Rotary mower gearbox input seal. How often gear oil change? #21
We were in the upper 80's with high humidity in the same month that we got snow storms :confused3::thumbdown:
   / Rotary mower gearbox input seal. How often gear oil change? #22
High 80's with what kind of a storm? Is that anything like a Cat 3 hurricane?We have those both in the same month!
David from jax
   / Rotary mower gearbox input seal. How often gear oil change? #23
I had leaky gearbox problem too. After all the regular oil leaked out I added in a bottle of STP stop lead and then grease gunned in JD Corn Head grease until just above full line. Corn Head grease solidifies quickly after melting due to gear reaction and therefore doesn't leak. I haven't had any leakage since (and didn't have to mess with replacing gaskets). Make sure you use Corn Head grease. Others won't work.
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
6ft Teakwood Indian (A57454)
6ft Teakwood...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
2016 Hyundai Veloster Hatchback (A56859)
2016 Hyundai...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
1667 (A57192)
1667 (A57192)
