Rotary mower gearbox input seal. How often gear oil change?
   / Rotary mower gearbox input seal. How often gear oil change? #21
We were in the upper 80's with high humidity in the same month that we got snow storms :confused3::thumbdown:
   / Rotary mower gearbox input seal. How often gear oil change? #22
High 80's with what kind of a storm? Is that anything like a Cat 3 hurricane?We have those both in the same month!
David from jax
   / Rotary mower gearbox input seal. How often gear oil change? #23
I had leaky gearbox problem too. After all the regular oil leaked out I added in a bottle of STP stop lead and then grease gunned in JD Corn Head grease until just above full line. Corn Head grease solidifies quickly after melting due to gear reaction and therefore doesn't leak. I haven't had any leakage since (and didn't have to mess with replacing gaskets). Make sure you use Corn Head grease. Others won't work.
24017 (A56859)
24017 (A56859)
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
