Rotary hay cutter
   / Rotary hay cutter #21
LOL sounds WAY too familiar. We have the dryest 2/3 (ie: driest ground) of the lightest (ie: thinnest grass growth) of our hayfields cut right now, hoping it will dry enough to bale on Sat before the 30% chance of scattered thunderstorms shows up.
Aaron Z
Farmers around here said they need at least 1 month of sunshine, 2 months being ideal to get good crops in. Down south is all flash flooding turning things into a province wide state of emergency.
   / Rotary hay cutter #22
How big of a 3 point one can I use on my m7040.
I think I'm just going try and buy some used stuff . . .
You may have to take what you can find, but my preference would be a Kuhn GMD600 or a JD265. Same machine, different paint. 7'10" cut. Probably about as "bullet-proof" mower as you can get. Plenty of them on the used market. (look on tractorhouse.com) There should be a Kuhn or JD dealer (or both) near you.
I wouldn't suggest anything bigger. It would just overload your tractor.
   / Rotary hay cutter #23
I pull a 9'3" cut Vermeer on a caddy with my M7040 with no problems. Before I bought the M7040 I pulled the same cutter with a M4900 but was low on HP in real good Coastal.
   / Rotary hay cutter #24
I have a brand new JD275 (Kuhn GMD 700) attached mower on my M7040 with Cab. Front loader and rear tires are filled. I was worried about the weight offset back there but once I got it adjusted and air'd up my tires it was just fine. The newer 275's or 700's have a better parking latch that keeps the 3 point fairly level and much easier to hook on to. They don't flop down at a bad angle like some of the older ones.
JD has them on sale this month in South Texas and they were about $3500 cheaper than from Kuhn believe it or not.
By the way, I was a little worried about not have a float function on my remotes but I'm on fairly flat ground and it seemed to do fine as well as my wheel rake. $1000 is a little steep for another remote.
Richard
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
DIGGER DERRICK (A55973)
DIGGER DERRICK...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
John Deere 3025E (A53317)
John Deere 3025E...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
