Rotary cutters
/ Rotary cutters #1
poli33
Any body had any experience with the galvanized 'Bushmaster' rotary cutters from "Onlineattachments.com"? Any comments, good, bad or otherwise?
/ Rotary cutters #2
Most rotary cutters that see moderate to heavy use will need welding somewhere on the deck soner or later, especially R/C's mounted on a SSL. Welding galvanized steel emits poisonous gasses and is not recommended without specialized personal safety equipment. Given proper equipment storage, rust-through is not a problem for machines built of heavy gauge steel, and rust protection is the primary advantage of the galvanizing proces.
Bottom line, I think a galvanized rotary cutter is a gimmick and a distinct disadvantage that I would actively avoid.
/ Rotary cutters #3
Drink milk after welding galvanised, or zinc based paints. It takes up the zinc and drains it off with your urine. You can get pretty sick of zinc vapours but when cleaning it with an angle grinder before welding (which you need to do to get decent welds anyways) it isnt so bad.
Welding paint is just as bad for your lungs.
/ Rotary cutters #4
I drink milk every day, but I'm not about to start breathing zinc fumes anytime soon. If you have such high standards about grinding galvanized surfaces, why are you welding painted ones? All of that crap is no good for anyone.
/ Rotary cutters #5
I have found the Davco rotary deck the most dependable/industrial out of the rotary cutters on the market. I think it is made by a company that specializes in forestry equipment in Canada. I have the 5' low flow model and it is by the far the best I've ever used or sold in the past.
/ Rotary cutters #6
I second that, I have a Davco 705HS (70" high flow) and other than blades I have had 0 problems with it.. With a few thousand hrs on it now it will need a new disc in the future but so far so good. They are not made to grind trees, but brush. If you stick to 4" less material u will be golden. They cut fast too.
/ Rotary cutters
What I'm looking for is a cutter for a PT 30. The only options I can find are:
1) the galvanized 48" Bushmaster
2) the 48" 4800LF Brush Wolf
3) Davco 48" model 472
I want a 48" and the 10 gmp of the PT 30 are limits.
The only reviews I've had are on the Davco and it was reported to cut good but "threw pieces up to 200 yards". Maybe exageration, but I figure with the open front it might have a tendency to throw things around more than the other two which are semi closed in front (chain).
Any rate, I would greatly appreciate any thoughts.
/ Rotary cutters #8
A PT30 aint gonna throw nothing 200 yards. You will be hard pressed to cut anything over 1" with that little guy, save your money and buy a bigger machine or a walk behind brush cutter. Im not trying to be a smart azz those are just the facts.
/ Rotary cutters #9
The risks of welding on zinc are greatly exaggerated. Wive's tale stuff really. You're never supposed to inhale the welding fumes nomatter the coating and you will always be able to find a document that supports this. If you actually look you can find that zinc welding is just as dangerous as anything. Plenty of welding gets done on galvanized steel.
/ Rotary cutters #10
Highbeam,
I did a quick google search of what seemed like reputable sources and you may be on to something. It's probably best to stress the 'never supposed to inhale any welding fumes" part, and while I did read that galvanized does increase the "Volume" of fumes I won't actively avoid welding galvanized. I'll be satisfied with just being conscientious and taking a little extra precaution.
Thanks,
UNUSED CFG INDUSTRIAL QK20R MINI EXCAVATOR (A62130)
UNUSED CFG...
2016 FORD F650 ROLLBACK (A59909)
2016 FORD F650...
2005 Sterling L7500 Fuel and Lube Truck, VIN # 2FZHATDC95AV42993 (A61165)
2005 Sterling...
UNUSED WOLVERINE SB78-78" ROCK BKT (A62131)
UNUSED WOLVERINE...
16ft. Teak Wood Table (A61569)
16ft. Teak Wood...
2011 Ford F-250 Knapheide Service Truck (A61568)
2011 Ford F-250...
