rotary cutter.
/ rotary cutter. #1
gravelman
Platinum Member
NH
Kubota 2650
Ok here is a new on on me... got a new set of blades for my Kodiak 5 foot brush hog... without giving it a second thought, pulled off the old blades and installed new one. Went to cut and they did NOt cut. Compared the new with the old and the new blade had the sharpened side just the opposite of what i have been using for 100 years. In other words, i had clockwise blades instead of counter clockwise. Never ran into this issue before. Anyone out there with comments about this ??? thanks.
/ rotary cutter. #3
No, there are forward and reverse rotation blades. My Hydraslide Hardee ditchbank cutter has blades sharpened on both sides. You can reverse the cut by swapping the hoses on the pump. You can buy the sharpened on either side or both sides.
/ rotary cutter.
You did not read my post carefully , the sharpening is just the opposite of the blades i took off... It is impossible to put the blades on upside down....thanks Workinonit....you get it.
/ rotary cutter.
on my particular mower it is impossible to install blades upside down... safety feature. The blades are not flat.
/ rotary cutter. #7
did the part # for the original blades match # for new? aftermarket i assume?
/ rotary cutter.
after market... no number match..
/ rotary cutter. #9
do you have part # from Kodiak that you can price on Amz? have had surprisingly good luck on finding replacement parts that way. if the knives are reverse sharpened as you mention, you have a boat anchor unless refundable.
good luck
/ rotary cutter.
im looking for someone local that might have a mower they could use these on. Thanks for the tip too..
/ rotary cutter. #11
Check with someone that has a 15' batwing. A batwing mower usually has clockwise on one side and counter-clockwise on the other side.
/ rotary cutter.
ok will do that
/ rotary cutter. #13
Dumb question. Can you sharpen the back side and use the new blades?
/ rotary cutter. #14
Do you have any side by side pictures of these blades?
/ rotary cutter.
it would be way too much work to sharpen the other side... no picture..but just imagine a blade with sharp side and then just the opposite.
/ rotary cutter. #16
If the blades are like mine then one would have a 25% chance of randomly installing the blades correctly.
1. Observe the direction of rotation while running.
2. Orient the blades so that the cutting edge is the lead edge.
3. Make sure the trailing edge of the blade is angled up so the blades act like a fan and lift the grass as the brush hog turns.
4. Go mow some grass and enjoy the day.
Example: If the mower deck turned in the direction of the arrow,
then “c” would be the correct orientation.
/ rotary cutter.
understood...thanks for all that. My blades are NOT flat...and cannot possibly be installed incorrectly , they would not rotate at all
/ rotary cutter. #18
If you didn't want to buy new blades, perhaps you might look at the gear box on your cutter and see if the gear set can be flipped around. Many gear boxes are made that way for various applications.
/ rotary cutter. #19
This is common. It's even possible to have two directions for the same mower. My 10ft has the same gearbox left and right, so they accommodate for this by having opposite-sharpened blades on the left side. Take your old blades into any good dealer/tractor supply and they should be able to get you what you need. Might even find them at a farm supply store if your bh is a common brand.
/ rotary cutter. #20
either installed upside down or maybe universal blades that are not compatible with your mower,I have b ought universal blades that had different bends in them with did not cut very well,I always just bite the wrench and buy OEM blades now,I replace mine every season instead of sharpening
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
832856 (A61166)
832856 (A61166)
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
