Rotary Cutter
/ Rotary Cutter #1
mhart
Hello
Basic question here. I have a B2920 that I recently obtained. I have a rotary cutter to hook up. I also have a MMM that I have been using.
Once I hook up the rotary cutter, do I have to disconnect the driveshaft to the MMM when I am using the rotary cutter?
Thanks, Matt
/ Rotary Cutter #2
No, you just need to change the PTO selector from MMM to the rear PTO.
/ Rotary Cutter #3
No, if you put the PTO engage lever in the 540 position, the mid-mount shaft should not turn. If I remember right, that is when the lever is all the way back.
You can 1st raise the MMM up all the way and put the mower height knob in the "top" position and that will hold it up. Then hook up the mower on the back.
/ Rotary Cutter
Great that is what I needed to know. I was most concerned about having the mid PTO running the MMM but it sounds like it wont turn if I am using the rear PTO.
I just didnt want to run over something and damage the MMM.
Thanks again, nice to have the resource of knowledge on this forum!!!!!:
KSI Conveyor (A63689)
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
