Mowing Rotary cutter with dual blades
   / Rotary cutter with dual blades #1
Rfisher42
Louisville, KY
JD 5400
What is the reason/need for dual blades, looks like a munching setup. Has anyone done this and what was your reason for doing this. Are you happy with results?
Thanks for your commits.
   / Rotary cutter with dual blades #2
sorry I cant remember where I just read, but when I did a search for "blades" I read where a guy did this and it helped his discharge of the clippings.
   / Rotary cutter with dual blades #3
If you are thinking of the standard single gear box rotary mower it runs two blades that attach to a center disk or stump jumper. The blades will pivot where they attach to the stump jumper so if they hit an immovable object they swing out of the way rather than break the mower. If your thinking of something else we will need more details. I have never heard of a rotary mower that had a mulching setup.
MarkV
MarkV
I have a JD 609, the parts catalog list a option for dual blades or the normal single blade. In both cases these are connected to the main bar.
I have attached the John deer drawing giving the dual blade option.
  • 609 John Deere blade bolt and assembly.pdf
   / Rotary cutter with dual blades #6
Dual blades are called shredding attachment. They were mainly used yrs ago before all the no-til farming practices started for the chopping up of row crop stalks such as cotton,corn & milo. Back then the operators manual stated "not to use for pasture mowing" but the shredding attachment also had a stationary blade the bolted to the outside of the cutter housing.
   / Rotary cutter with dual blades #7
Rfisher42
Can you instruct this computer dummy how to download a pdf file?? I know how to download JPEG & GIF photo's Thanks,Jim
Jim sorry I didn't realize this question was directed to me, did you get it figured out?
   / Rotary cutter with dual blades #9
Rfisher42
NO I can't download a PDF file. Can you please can help?? Thanks Jim
CASE 584E ALL TERRAIN FORKLIFT (A52708)
CASE 584E ALL...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A56857)
2017 Skytrak 10054...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
