Mowing Rotary cutter swing arc
   / Rotary cutter swing arc #1
JFoy
Clemmons/Lexington, NC
Kubota BX25D
I've got a Kubota BX25D and Landpride RCR1248 rotary cutter. Just started using the cutter and noticed it swings quite a ways left to right. What do you guys recommend as far as the swing arc for one?
Thanks,
JFoy
   / Rotary cutter swing arc #2
Usally somewhere in the geometry of totally up or down there is a position where the stabilizers are tighter than at any other position. I adjust my implements to have about 2-2.5 " of sway here at the most.
Then it will be just a bit more on the ground. It's rough on the tractor and equipment to have it banging around all over the place.
   / Rotary cutter swing arc #3
I prefer to keep mine mostly tight with just a smidgen of play.
   / Rotary cutter swing arc #4
I think you should tighten up your stabilizers to reduce most of the left to right play. A couple of inches is alright, but if it has enough play to get up momentum it can bend or break things, or in a very extreme instance like turning on a slope, provide just enough extra sideways force to tip a tractor.
   / Rotary cutter swing arc #5
I got rid of the turn buckle system and got some bars from Hodge, I like a bit of movement from side to side like Motownbrown.
   / Rotary cutter swing arc #7
My dad always had the turn buckle system and kept things tight without ever having any problems . As for me I keep things with a little forgiveness ( 2 or 3 inches ) and have never had a problem doing that either .
   / Rotary cutter swing arc #8
Why get rid of the turnbuckles? They allow you to set just the amount of slack you want, whether that's a very little or a lot.
I like my as tight as I can keep them without binding because my entire place is fairly steep hills, and I don't what the mower swinging around when I turn to a different side slope (the photo in my avatar is one of the most level spots on our place).
   / Rotary cutter swing arc #9
Much easier to adjust with different pieces of equipment, easier hook up and all my other tractors have the same type of stabilizer bars. It is considered a significant upgrade by most and is standard on bigger higher quality machines.
They also provide more strength in both directions.
All mine are fully adjustable, so no swing excessively on slopes or anywhere.
You really need a little play or you stand the risk of bending or stripping something more easily.
   / Rotary cutter swing arc #10
I got a pair also and it is one of the best things added to my L2501. I hated the turnbuckles. The stabilizers he builds are very heavy duty items. :thumbsup:
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
Woods Brush Bull 7' 3 pt Mower (A50514)
Woods Brush Bull...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
