Rotary Cutter Rotary cutter: pull type vs hitch
Status
Not open for further replies.
   / Rotary cutter: pull type vs hitch #21
</font><font color="blue" class="small">( Tongue weight is the down pressure exerted on the tongue of the tractor, not the amount of weight pulled by the tongue.
)</font>
No argument there.. however.. the dealer even told me that for my heaviest drawbar loads.. to use the 3pt drawbar.. not the swinging drawbar.. for exactly why imentioned.. to keep the swinging drawbar which is mounted to the bottom of the diffy, from ripping the bottom of the diffy off the tractor...
Soundguy
   / Rotary cutter: pull type vs hitch #22
</font><font color="blue" class="small">( You can't really adjust your mowing height by raising and lowering a 3pt. )</font>
Um... yeahright /forums/images/graemlins/tongue.gif
You most certaintly CAN adjust your mowing height with the 3pt hitch controls.
If you have your toplink adjusted correctly you should be able to fairly accurately adjust mow height., assuming your tractor has position control, and play inthe toplink connection.
With my 3pt mower tail wheels on the ground, I have 4" of "adjustment" over the front of the mower ( pivoting on the rear wheels ), before the mower rests onthe ground.. or the toplink bottoms out and lifts the mower. That yeilds a cut from about 3" to 7" before I would have to adjust the toplink for a different range. For my pasture clipping.. that works out great.
Soundguy
   / Rotary cutter: pull type vs hitch #23
As Soundguy says, you can definitely change your mowing height with the 3ph. I never change the height of my rear wheel. But with the rear wheel riding on the ground, I lower the 3ph to mow my upper pasture ( where I want it short) and raise the 3ph with the wheel still on the ground for the lower pasture where I mow it higher just to keep it knocked down for weed control.
Once again, I'm a noob and have no room to dispute what you say, but also once again, the manuals for 3pt hitch mowers indicate that you adjust your cut height by adjusting the rear wheel. It is certainly handy to have some additional control at the hitch.
Regardless, with the JD tag along I'll be trying, the ram will lift the mowing height significantly more than 4 to 5 inches, probably close to 18-20" (that's on a large tractor with a fairly high hitch though).
As a noob this has been an interesting thread. There are so many opinions that come with great authority but that are in direct opposition to one another. It can be hard to sort out what's what.
My conclusion, based on what I've read here, is that people seem to be extraordinarily passionate about what type of mower to use while the facts (or what seem to be facts) don't indicate significant enough differences to support such polarized positions. Fortunatley this also indicates that I'm unlikely to go way wrong either way.
Here is my current plan.
1) Try out the old JD 7' tag along with hydraulic adjustment. If it does well, end of story. Its free and I'll just use it.
2) If it works well but is hard for me to maneuver, I'll look into a small 3pt mower for tighter work to use in addition to it.
3) If it works well and handles well but cuts roughly (not aesthtically pleasing) I'll use it but may add a finish mower for the flat even areas around the cabin.
4) If it is unsatisfactory due to insufficient tractor HP, then I'l have to make the really hard decision in terms of 3pt vs pull type. But I'm leaning towards pull type, based on what I've read here, on my brother-in-law's advice and on seeing him in action with his various pull-types.
   / Rotary cutter: pull type vs hitch #25
The manuals generally state what you say. They recommend setting the rear wheel to the height you want and then adjust the 3ph so that the front of the cutter is slightly lower than the rear. The reasoning is that the blades cut at the front of the deck and are above the cut grass at the rear. If the front of the deck were higher than the rear, the blades would cut at the front of the deck and again at the rear. Theoretically that means the cutter is having to work harder and less effeciently. And I generally do run the front of my deck lower than the rear. But I can raise it level with seemingly no loss of power. And that is how I adjust my cutting height. I haven't actually measured it but I would guess I can change the height about 3" without the front being higher than the rear.
   / Rotary cutter: pull type vs hitch #26
</font><font color="blue" class="small">( but also once again, the manuals for 3pt hitch mowers indicate that you adjust your cut height by adjusting the rear wheel )</font>
You do have to set your rear wheels. to get in the ballpark max/min range of where you want to cut.. then it's the 3pt lift that does the fine control. as i said. once setup.. i can cut as low as 3" or as high as 7" without readjusting.. etc. that re-adjust would be toplink and tailwheels.. etc.
The opinions are not directly oposed.. there's just a little bit more to mowing than what is in the black and white 3 page manual..
Soundguy
</font><font color="blue" class="small">( You do have to set your rear wheels. to get in the ballpark max/min range of where you want to cut.. then it's the 3pt lift that does the fine control. as i said. once setup.. i can cut as low as 3" or as high as 7" without readjusting.. etc. that re-adjust would be toplink and tailwheels..etc.)</font>
Makes sense. Again, though, with the pull type you can do the full range of adjustment from the driver's seat, while moving and mowing.
And in regard to wheel placement, the pivot point of the wheel assembly on the units I've seen is not over the wheels, it is up on the deck, in some cases fairly near the gear box. With the pivot point there, your adjustment does not angle the deck as much as it would if the pivot point was back over the wheels. This is particularly true of the JD I'll be trying.
</font><font color="blue" class="small">( The opinions are not directly oposed.. )</font>
Well,um, yes they are. Not all, but plenty of them are. Just look back at issues like 'backing', 'terrain handling', 'weight distribution' etc. Diametric is the word that comes to mind.
</font><font color="blue" class="small">( there's just a little bit more to mowing than what is in the black and white 3 page manual..)</font>
Of course. That's why I'm here benefiting from the collective wisdom and correcting my misconceptions. /forums/images/graemlins/grin.gif
Tommorow I'll have the owners manual to the Kubota L4400 in my hand. Friday I'll be mowing.
Help me with another thing. I'm confused on attachment points. I understand the three point. I think I understand the basic hitch below the three point. But I also see (on some of my bother-in-laws machines) a bar connecting the two lower 3pt arms. I'm assuming this is a drawbar. Can a pull type mower be hitched to this type of drawbar? You mentioned that the 3pt may be even stronger than the regular hitch. If so, this would give the pull type mower significant adjustability. It would allow you to raise and lower the mower through a full range AND set the deck at the desired angle.
   / Rotary cutter: pull type vs hitch #28
A couple of things to keep in mind if you use the bar between the two lower links of your three point hitch, BTW the other bar that you call the basic hitch is the drawbar, moving the attachment point rearward may make your pto shaft too short, and you won't have any way to put down pressure on the bar except the weight of the cutter. If you drop the rear of the cutter in a hole, it could let the front of the cutter raise up and bind the pto shaft or throw something at you.
As always YMMV
Leroy
Yeah, I wondered about the PTO shaft. But I don't understand the part about the down pressure on the bar.
   / Rotary cutter: pull type vs hitch #30
</font><font color="blue" class="small">( Yeah, I wondered about the PTO shaft. But I don't understand the part about the down pressure on the bar. )</font>
The 'normal' connection point on a drawn mower would most likely be the 'swinging' ( fixed or not, under diffy, etc.. ) drawbar.
Some tractors actually do not have a swinging drawbar. and only have the 3pt drawbar.
Yes.. you could hook a drawn mower to the 3pt drawbar... Now.. in doing that, as the other poster mentioned, if the rear of the mower went down, the front of the mower would go ut.. and that would lift the 3pt arms, as most tractors do not have down pressure on the 3pt lift.. only 'lift'. To combat this.. you would use drawbar stays to hold the 3pt lift in a fixed position, and also sway bars to keek the bar from moving side to side. in stabilizing the bar in this manner.. you loose the 'lift' functionality.. but does make it safer.. as you won't put the pto in a bind.. etc.
Soundguy
Status
MISC LOT (A55745)
MISC LOT (A55745)
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
