Rotary Cutter on 2720
   / Rotary Cutter on 2720 #1
Rob-D
Veteran Member
Catskills
John Deere 3320
Anyone run 6' or bigger Rotary Cutter on a sub? I think my 2720 will run the pto fine but the weight of the 7' Woods is only about 50 lbs. more then the 6'.
Be nice to run a 7' but I may be stretching it although the 3pt. will lift 1250 at two feet out according to Deere and we know Deere takes extra care in their specs!.......Right!
Rob
   / Rotary Cutter on 2720 #2
I think 6' may be to big...the weight of a rotary cutter is pretty far back. You will definitely need your FEL on-and possibly some weight in the bucket.
   / Rotary Cutter on 2720 #3
Yep,.. might be able to disconnect the power steering pump, too. 'Cause those front tires won't hardly be markin' the tops of the grass!! :eek:
If it's a light-duty model like the JD LX6 you might get by. But the cutter weight might approach 40-45% of the weight of the tractor. Much less "pucker factor" if you went with a 5' model, though.
AKfish
   / Rotary Cutter on 2720 #4
If it is an open space you might consider a pull type cutter, much easier on the tractor. I used to have a Mohawk 6' cutter pull type, easy to hook up and did a nice job for many years.
Steve
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
UNUSED KIVEL TRAILER MOVER ATTACHMENT (A54757)
UNUSED KIVEL...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A55787)
2017 JLG Skytrak...
(APPROX 64) 2X6X8 PINE LUMBER (A54756)
(APPROX 64) 2X6X8...
2016 CHEVROLET 3500HD CREW CAB SERVICE TRUCK (A54756)
2016 CHEVROLET...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A55745)
2006 V.E...
