Rotary Cutter Rotary cutter offset mount
/ Rotary cutter offset mount #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
I bush-hog the edges of my hay fields to keep all the brush back but I have lost some ground over the years. I've always thought that it would be great to have my cutter offset a foot or so beyond the edge of my tire. This would be great for me in two ways:
1. it would allow me and my tractor to stay out of the pickers/branches yet still cut further off the edge of the field.
2. I have some drainage ditches along my driveway and in other various locations on the property. Offsetting the cutter would allow me to drive along the ditch edge and the cutter could overhang the ditch allowing me to cut the weeds right up the the edge.
So, I found that several rotary cutter manufacturers offer an offset mount as an option and that has gotten me to thinking about one for mysel but I have some questions:
1. Does anyone here use an offset mount? If so, what brand(s)?
2. How much offset can you get out of it?
3. Can you easily switch betwenn offset and regular mounting?
Thanks for the help!
Anyone...? Anyone at all...?
/ Rotary cutter offset mount #3
Why not just slide the mower to the side and lock it in with the link chains. I can get 4 or 5 inches of overhang on my rig doing this.
I thought of that as well, but I have two problems I'm looking to solve. I just upgraded my tractor (delivery today!) and it's a foot wider than my old tractor. My rotary cutter is 5' wide so I'd be using 6" of lower link adjustment just to get it even with one side of the tractor. That's why I was wondering how much offset you can gain with the offset mounts. I may not be able to do what I want with the 5' cutter anyway, but ideally I'd like to have a cutter offset to a good fott from the edge of the tractor. This would get me under the brush along the fields and allow me to mow off the edge of the ditches without having to get too close.
/ Rotary cutter offset mount #5
Sounds like a useful idea but the nerd in me would check it out a little more.
You don't want a universal joint to operate at too severe of an angle because the stresses in it go up after a certain angle. So whether you just offset the cutter with the rear links or use a special mount, you still have that angle limit to deal with. It might be worth contacting your pto shaft engineering dept to see what max angle they recommend.
This is a stretch for my memory but I THINK the maximum recommended angle for a universal joint in general is 11 degrees. If so, then an approximate side shift at that angle would be about 20% of the (u-joint to u-joint) pto shaft length when the cutter is straight back. For example, if the shaft measures 40 inches, side shift would be less than 8 inches. Worse, if you have much vertical angle due to height differences between the gear box and pto stub, then the max side shift angle component is reduced.
Does that a special offset mount use a modified drive train?
John
/ Rotary cutter offset mount #6
...I just upgraded my tractor (delivery today!) and it's a foot wider than my old tractor. My rotary cutter is 5' wide so I'd be using 6" of lower link adjustment just to get it even with one side of the tractor. ...
Time for a new implement as well!
How about a sicklebar mower, or a flail mower? The flails usually have an offset adjustment ability, and of course the sickle mower is always cutting off to one side of the tractor. Both of these are rather expensive though.
John
John,
It doesn't appear to which was why I was questioning it. The only picture(s) I can find are in parts manual like this one (see pg. 27) and not actual photos of one on a tractor or in use.
http://www.servis-rhino.com/RhinoManuals/parts/00757419P--- CY60 CY72 PUB 08-05 Rev 05-07.pdf
The only advantage I can see by this diagram is that you could use a quick-hitch style adapter on the back and get the offset from this without having to play with the lower link arm adjustments...?
Most of the newer sicklebars aren't made for brush, just for cutting hay as I've been told. I have an older Massey Ferguson sickle bar that's 7' long. That would work for cutting over my ditches OK but not so good for cutting around my feild edges I'm thinking because the brush is thicker and there may be some hidden obstacles that wouldn't phase a rotary cutter but may do some damage to a sicklebar.
I know nothing about flail mowers at all except they appear to be pricey... I guess I should do some homework on these...there is a long-running thread here on them that I haven't really paid any attention to.
/ Rotary cutter offset mount #8
I bush-hog the edges of my hay fields to keep all the brush back ...<snip>... but I have some questions:
I have a Brushog 7' rotary cutter that offsets about a foot. I don't know if it is still made, but here's a link to the BH 8' model that offsets . . .
Bush Hog&reg - Performance You Can Count On
This model is a heavier and wider version of mine - weighs more, requires more hp etc.
/ Rotary cutter offset mount #9
My idea is to hang a mower off to the side that would extend up to 4 to 6 feet off to the right and left side and the end of the tractor.
It could be used on both the front and the rear of the tractor.
With a 2 wheel dolly it could be towed behind any tractor or ATV.
/ Rotary cutter offset mount #10
The Fence Mower: Fence Mowing Made Easy!
/ Rotary cutter offset mount #11
Recently purchased an old Ford 451 Sicklebar mower for $600.00. While its a PITA getting hooked up it has done a great job on property edges, pond and driveway banks. As I get to use it more I'm sure I'll get the hang of it. Had no problem with small brush. Glides over rocks but will come to screeching halt if run into solid dirt. As my tractor is 8' wide and bushog is 6' I was losing the battle around property edges, no more. Also easier to view cutting path without straining neck. Not as nice a cut as bush hog but a whole lot less fuel to run.
I am looking into the benefits of a flail mower but I am certainly going to look into hooking up the Massey Ferguson sicklebar mower that I bought a few years back. I tried hooking it up to my MF 1433V without much success, but I found some additional help from the good folks here at TBN in the way of manuals that may help me to hook it up on my new tractor.
/ Rotary cutter offset mount #13
I have a Bush Hog model SQ84T which is a 7' twin spindle mower with an offset on the right hand side. The left side tracks along the outside edge of my tire and the right side extends out about 18" to 24".
Personally I like to use the side that tracks with my rear tire along the edge of the fields because I have found that if you catch a tree or large stone with the offset mower it will bend the crap out of the mower linkage. I used to use a 7' sickle bar mower on our old JD B for the edges and hope to have that rig running next year again.
/ Rotary cutter offset mount #14
John
My idea is to hang a mower off to the side .
The beauty of this is no universal joint to deal with.
/ Rotary cutter offset mount #15
/ Rotary cutter offset mount #16
D. M. F. said:
I've always thought that it would be great to have my cutter offset a foot or so beyond the edge of my tire. This would be great :
How are you going to trim a 3 foot wide ditch with a cutter that only reaches a foot past the tire?
My ditch lines are filled with rock a few inches below the ground level. I just want the mower to hang off the side of the ditch slightly to cut the weeds on the edge. I'd have to make a pass on both side of the ditch to get both edges...
/ Rotary cutter offset mount #18
I just want the mower to hang off the side of the ditch slightly to cut the weeds on the edge. *I'd have to make a pass on both side of the ditch to get both edges...
2 of my ditches are along the foot of a bank that is to steep to get a tractor on so I can't make a pass on both sides.
Another ditch is along the state highway that I can only mow from my side as it's not safe to have the tractor out on the road to get the other side.
This is why I want to hang a mower out from the 3 point hitch that would have an adjustable reach up to about 6 feet out from either side or either end of the tractor.
To cut further off the edge of the field.
have you considered backing the Hog over what you're trying to cut rather than driving along side of it?
/ Rotary cutter offset mount #19
There are ton of offset rough cut mowers used in my part of the world. Our climate is great for trees and lots of branches and ditches so lots of cutting like you talk about. Also ponds. There is a local company who saw a great need and makes a great cutter for that. Pricey and heavy but they offer several models including boom mowers now. The also made a rough cut model like you are asking about and I had one for a good while and no problems with the pto shaft angle. It was off set maybe a foot past the right tire (they offered the offset either way). The gearbox was not mounted straight but rotated to reduce the angle for the shaft.
On their cutters that are really off set they use hydraulic drive cutters with pump that is pto driven. They really build a top quality product. Their old standard design 3 pth hitch cutters will handle a lot. Warning...you need at least as much tractor weight as they tell you. You have a lot of weight hanging on your right rear tractor tire. A LOT. Quick piece of long time user advice, if you are using one around a pond or any where with a dangerous drop off, cut in reverse. That wall if you hit something the tractor swings away from the drop instead or into it.
Have never posted a link here before and hope it shows up.
HARDEE: Agricultural Equipment
Others companies have made similar cutters but no one seems to build as solid an unit as does Hardee. No, I don't work for them but very much respect their product. kt
Well...yah, I do that now in some areas but I get roughly a 60" cut for each back-up; my driveway is 1500' long so that's a lot of backing up; my neck hurts now just thinking about it! :)
There are some areas where that is not practical as well due to obstacles, property lines, etc.
Plus, it doesn't really address the filed edges...
Have no fear; your attempt at posting a link was successful! And, it's a very interesting product...I really expected it to be significantly more expensive than it is really...I have to look at these in more detail; thanks!
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
2012 Ford Taurus Sedan (A66738)
2012 Ford Taurus...
JOHN DEERE 5403 TRACTOR (A67714)
JOHN DEERE 5403...
