Rotary Cutter Rotary Cutter Model Info.
/ Rotary Cutter Model Info. #1
jbirdmotox
I have found a used John Deere rotary cutter. It is a model 403. I haven't really found much info. about this model. Is anyone familiar with this model? Is it an entry level piece? Any ideas on the new price on a comparable unit? It appears to be in decent shape but I would need to buy a drive shaft. I would be using it on the back of a Kubota B20. Any problems with this? The asking price is $525.
Thanks, Jon
/ Rotary Cutter Model Info. #2
I would say it depends on condition and size, KK sells a 5 foot for around $500. ( new ) and I bought a used Howse 5 foot in nice condition for $200. with drive shaft. How wide are you looking for and have you checked with your local tractor places? I bought mine used from a JD dealer
Jim
Well, I was looking for a 5' really. I was quoted $1400 for a new unit at the local JD dealer. That was for a Land Pride.
/ Rotary Cutter Model Info. #4
Jon, unless you have to have green? Look around lots of better prices out there, I want a Bush Hog 286 and I am too frugal to spend $1800. on a 6 foot brand new mower, It is the best, but my used Howse will work fine.
Really shop around
Jim
Thanks for the info. I felt for maybe $300 it may be worth it but $500 was too much. You pretty much just confirmed my thoughts.
Jon
/ Rotary Cutter Model Info. #6
/ Rotary Cutter Model Info. #7
The Howse is not a bad unit if you're not cutting heavy stuff. If you need parts is where the trouble comes. I and several others on here have had issues getting much service from Howse.
/ Rotary Cutter Model Info. #8
MrJimi said:
... KK sells a 5 foot for around $500. ( new )
Unbelievable price. A 5ft rotary cutter weighs about 500-600 lb. Its material cost only will be about $250-300. Add gearbox, blade, etc which cost much more than simple sheet metals. Add labor cost. Add manufacturer's and dealer's profit, etc. A "new" rotary cutter can't be sold for less than $800 which is my selling price. Are you sure about this price $500?
/ Rotary Cutter Model Info. #9
The TSC near me sells the 5' KK for about $650.
I bought a used JD LX 6 which is their 6' light duty model but it is more heavily built than the KK and Howse models. It came with full chains, laminated tail wheel, good paint and only a few dings on the deck with a couple of little rust spots. Looks new from 5 feet away. The JD dealer sold it to me for $800. Works great. I felt like this was a good deal, not great, but good. There are deals to be had. Keep looking.
/ Rotary Cutter Model Info. #10
The 403 is no longer listed as a current model. How big is it? Is it a 3pt hitch or pull type? JD currently uses 'LX' to indicate light duty, 'MX' to indicate medium duty and '609'. '709' etc to indicate heavy duty. How well is this thing made?
It is a 4' model. Compared to the 5' Land Pride it looked real, real cheap. It must be an older LX type model.
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Hydrapack 6 Row Lay-By-Rig (A64127)
Hydrapack 6 Row...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
