Rotary Cutter Discharge
/ Rotary Cutter Discharge #1
Piperflyer
USA
Kubota3030HST
Do you recommend a side or rear discharge on a finish mower and why?
/ Rotary Cutter Discharge #2
I have never seen a rotary cutter with anything but a rear discharge. Are you possibly talking about a rear finish mower?:confused:
/ Rotary Cutter Discharge #3
I have a side discharge finish mower and wish I had gotten a rear discharge .. why ... I am not happy with the windrows it leaves ...
Leo
/ Rotary Cutter Discharge #4
Get a rear discharge. It's easier to cut up next to stuff. Rear discharge won't leave a windrow so much, but it will leave clumps of grass if it's real high and/or wet.
/ Rotary Cutter Discharge #7
There are plenty of side discharge rear mounted finish mowers and some folks like them. Not having tried one, I can't say, but I have had two rear discharge, rear mounted finish mowers and really like them. If the grass is high or wet as has been said clumps will remain. The rear safety chains on my bush hog model will sweep them up into piles as you drive. I have taken the chains off and also put gator mulching blades on and am quite happy with the result.
/ Rotary Cutter Discharge #8
my 72" MMM is a side discharge. the rear discharge decks are built a lot diffrent as to not haveing to toss all the clippings out the right side.
If i leave the discharge flap down, it windrows so bad it looks like ive raked it and am going to bail it.
IF i had to choose i would pick rear discharge.
nothing to add to my previous post... still feel the same way
/ Rotary Cutter Discharge #9
Rear discharge cause it can cut taller grass easier and better, also you can cut closer to trees, buildings...etc on both sides of cutter which reduces your cut time.
2014 Freightliner Derrick Digger (A60352)
2014 Freightliner...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
Westerbeke 6EKOD-CP1 6kW Marine Generator (A59231)
Westerbeke...
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
