Rotary Cutter Rotary cutter discharge
   / Rotary cutter discharge #1
DirtyDusty
North Louisiana
New Holland TN75
I have a 5' Rhino rotary cutter I pull behind a tc35 New Holland. The problem is when I use it to mow my pasture it piles all the grass up on one side as it cuts. I tried taking the guard off the back to see if it would discharge more evenly, but that didn't work either. I adjusted it so the rear end would be higher than the front and that didn't work either. Any ideas?
   / Rotary cutter discharge #2
I've found with my mowers that it matters which side in running towards the side already mowed. My Bush Hog 286 likes the right side "in the clear". My Woods BB840 likes the left side. They scatter the clippings better that way.
Rough cut mowers aren't known for their ability to leave a "clean" field for the most part.
   / Rotary cutter discharge #3
raise the side that the grass is building up on. You can do this with the 3pt arms. Raise it up 1-2 inches higher, also cutting higher can help also. This gives more room for the grass to discharge and not ball up and "rope" alongone side. Mike
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
2021 Keystone RV Passport 3221BH 36FT T/A Travel Trailer (A50324)
2021 Keystone RV...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
