Rotary Cutter Rotary cutter discharge
   / Rotary cutter discharge #1
DirtyDusty
North Louisiana
New Holland TN75
I have a 5' Rhino rotary cutter I pull behind a tc35 New Holland. The problem is when I use it to mow my pasture it piles all the grass up on one side as it cuts. I tried taking the guard off the back to see if it would discharge more evenly, but that didn't work either. I adjusted it so the rear end would be higher than the front and that didn't work either. Any ideas?
   / Rotary cutter discharge #2
I've found with my mowers that it matters which side in running towards the side already mowed. My Bush Hog 286 likes the right side "in the clear". My Woods BB840 likes the left side. They scatter the clippings better that way.
Rough cut mowers aren't known for their ability to leave a "clean" field for the most part.
   / Rotary cutter discharge #3
raise the side that the grass is building up on. You can do this with the 3pt arms. Raise it up 1-2 inches higher, also cutting higher can help also. This gives more room for the grass to discharge and not ball up and "rope" alongone side. Mike
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
BRADCO HP600 COLD PLANER (A52707)
BRADCO HP600 COLD...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2003 Big Tex 10PI...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
