Rotary cutter bit the dust! Please advise
   / Rotary cutter bit the dust! Please advise #1
horticattleman
South Central Louisiana
CT335
I have a 72" Bobcat rotary cutter what sucked up a small log that was just a little too much. So much for a shear bolt. Anyway the gearbox says QMC but when I look it up it is in Chinese:confused2: Any idea on a replacement for this? It is a 1:1.47 Part # 01-182NHG
Thanks
   / Rotary cutter bit the dust! Please advise #2
How long have you had the cutter? Check your warranty statement on it, I think the gear box has a 5 yr warranty. If you were using the correct shear pin and it did not save the gear box, I believe Bobcat will cover it if less the 5 years (60 months) old.
   / Rotary cutter bit the dust! Please advise #4
man, 1 year, I used to beat the dog chit out of my old land pride, and it took it all.
Doesnt say much for the Bobcat gearbox!
   / Rotary cutter bit the dust! Please advise #5
Must have been a defective gear box. Bobcat is pretty good on warranty, they usually will do the labor to! I've seen those 72in cutters take over 4in saplings, though it was on a CT450 it turned them to mulch! instead of a shear bolt, what about investing in a slip clutch?
   / Rotary cutter bit the dust! Please advise #7
Rhino used to make the loader. I wonder if they made the mower, as well?
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
