Rotary blade replacement
/ Rotary blade replacement #1
Laminarman
Upstate NY
TC40DA
Apologies, but I can't search any forums, I get an "internal server error".
Is replacing the blades on my Land Pride 6' rotary cutter beyond the scope of a do it yourselfer? I have the instructions, just not sure how hard of a job it is. Mine are beyond sharpening at this point. Thank you.
/ Rotary blade replacement #2
I do not have a landpride but I have replaced the blades on Woods RC. I don't think you will have much of a problem. On mine the pin that holds the blade on comes up through the bottom and I had my wife start the nut once I got the blade and pin in place.
/ Rotary blade replacement #3
depends on the model.. and the way the blades attach to the stump jumper or blade carrier.. generally there are shouldered bolts and locknuts.. some can be accessed from the bottom.. some have a hole in the deck for a ratchet and big socket.
that and lock the input shaft with a piece of rebar.. etc.
soundguy
/ Rotary blade replacement #4
For a do-it-youselfer, the most challenging part will be the size of the bolt/nut. You'll probably need a 3/4" breaker bar and socket. I had to use a 4' - 6' pipe (cheater) slid over the breaker bar too. I didn't have a 3/4" set until I had to change the blades on mine. I've used it more than I thought I would after that.
/ Rotary blade replacement #5
It's a do it yourself job with the proper tools and some patience, and lots of penetrant like PB blaster. The nuts are large, and likely rusted on. As mentioned before you will need 3/4 inch drive sockets and a good impact wrench or breaker bar. I would recommend soaking them with the PB stuff and give it some time to work. I soaked mine several times as I had to wait several days for the sockets to come in the mail. You can buy individual ones if you don't want to buy a whole set. Good ones are pricey. With the right stuff it's not too bad. Prior to doing the right way, I tried to get them off with the the tools I had on hand. It was a complete waste of time, you need the right tools for this job!
/ Rotary blade replacement #6
might hit a chinese store.. I got a set of 3/4 sockets, ratchet and breaker bar from them for 30some odd bucks.. big monster things... ugly.. but tough.. have yet to break one.. even doing pull up on the afore-mentioned 4' and 6' helpers!
soundguy
Thank ya kindly folks! I have a 1/2" air impact wrench on a decent compressor, but sounds like 3/4" is more like it. I'll start soaking and see what else comes up. By the way, if you've ever used Kroil, you'll never use PB Blaster again, it's that much better : )
/ Rotary blade replacement #8
I got mine off with a 1/2 inch impact wrench with a 1/2 to 3/4 adaptor. Its a pretty powerful wrench, and the bolts had been well soaked. I'll give Kroil a try.
/ Rotary blade replacement #9
When you replace the blades buy new bolts and nuts. removing the old the threads seem to lock up and the nut is unusable. To get the old bolts nuts to release easier use a cold chisle to make a streach in the nut threads this is easyest to remove. You sure don't want a used bolt to let the blade loose under the bush hog experance I have had the blade spun approx. 1/8 mile after cutting a slice out of the the metal side of deck.
if the stump jumper is banged up cheaper to purchase a complete lower set up.
ken
/ Rotary blade replacement #10
Since I killed the thread will make one more comment. The new blades cost money and using the old bolts worn and damaged by what ever method of removing.
This was my way of stating I't is not recomended to use old bolts for his application.so why save the worn bolt.
ken
/ Rotary blade replacement #11
On my Landpride RCR 1860 there is an an access hole through the top to get to the blade nut. There is a round rubber plug that has to be removed. I use a 1/2" impact gun and a socket on the blade nut. A couple of blips on the impact gun and the blades fall on the floor. You can crawl underneath and use a 15" Crescent wrench with a cheater bar and get the nuts off. The Crescent wrench method will put about a pound of dried horse poop and grass in your mouth and nostrils and you will lose a few ounces of flesh off of your knuckles. For the macho "No Pain, No Gain" guys give 'er a go with the Crescent wrench.
FORD F-350 REAR END (A62131)
FORD F-350 REAR...
207271 (A52708)
207271 (A52708)
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
