ROPS & Seatbelts WORK!!
/ ROPS & Seatbelts WORK!! #1
Garycw
Platinum Member
Oh-Ky-Fla
JD 1025R w/ fel, Farm Pro 2425, ford 841 & 851
Just a reminder they are not there just to annoy us. They do save injuries and Lives!!
While moving gravel with a little JD1025 today I got to try them out :(
Bucket was low, Ballast was present and being careful. Rear wheel got in a very small rut and was all she wrote. Hold on tight and tuck in. I was very lucky today.
/ ROPS & Seatbelts WORK!! #2
It looks fairly level. I dont see how that could have happened with the listed parameters. ... The seat belt was of no use, as you could have just stepped off as it rolled to spare you the jolt.
Looks are deceiving and to step off, easier said than done! It had a bucket full of gravel and lots of humps & ruts. I tried to correct it when felt it lifting, but was quickly beyond point of no return. If this had been in water I'd have needed a seatbelt cutter.
/ ROPS & Seatbelts WORK!! #4
When you are doing something like that keep the bucket as low as you can and if it starts over set the bucket down on the ground. Ed
Thanks for the tip. I guess I didn't get it down quick enough. Seemed to just have time to hold on and tuck. You just can't be too careful around tractors & equipment no matter what the size. If this had been closer to edge of new basement it'd have been a 9' drop with lots of rebar sticking up
/ ROPS & Seatbelts WORK!! #6
Sounds like you were moving or turning a bit too fast. That conflicts with the careful parameter. W/O seatbelt its extremely easy to step off on the low side, but carries its own risk. ... If ROPS prevents further roll youre home free and would actually fare better that the jolt from staying in the seat.
/ ROPS & Seatbelts WORK!! #7
The tractor aerodynamics is quite poor making them sensitive to cross wind.
Yes SPY I was trying to move forward while turning. Not fast, but the wheel got in a rut and lost its balance. Didn't teeter or give much warming, gust went. I'll take the jolt of seat belt over a body part being smashed & pinned. I have larger tractors without ROPS or belts and hope I could jump, but may be wishful thinking. I'll admit I'm new to fel and learned a lesson today unharmed.
Last year I was ran over by another tractor when a wrench dropped on a starter. Luckily here to tell it.
/ ROPS & Seatbelts WORK!! #10
I have been moaning for years that you can roll a tractor on flat ground due to ruts and soft spots when I hear people say they don't use ROPS or seatbelt because their land is flat. This is a perfect example, though I am sorry you had to go through that to make my point!! Years ago I felt a similar rollover motion starting when one side of the tractor got into some soft mud on flat ground. Luckily I didn't go over but I got the sensation.
/ ROPS & Seatbelts WORK!! #11
I keep the loaded bucket an inch or so above the ground. Center of gravity stays low and it can be dropped on the ground instantly if need be.
/ ROPS & Seatbelts WORK!! #12
With a full size tractor, distances are too great. With ROPS you must stay in the seat. If youre not wearing the belt, hug the steering wheel. ... W/O rops you must jump to the high side. Thats something you wish you could practice at.
,,,That runover has me thinkin. Leaving tractor in gear as a "park brake" can be dangerous.
/ ROPS & Seatbelts WORK!! #13
How much ballast is that empty bucket??? You need at least whatever the loader can lift, plus some.
I can lift 1800 and have 2000 in ballast. At times more ballast would be better.
These are anchored by the rear wheels so you must have enough to keep them on the ground!
/ ROPS & Seatbelts WORK!! #14
Wow surprised it tipped. How high was the bucket? Glad you were ok. i certainly wouldn't count on "jumping". If you got slowed down or hung up your dead, just not worth it. Good reminder to all of us to use the seatbelt when doing anything (even on level ground).
How much ballast is that empty bucket??? You need at least whatever the loader can lift, plus some. I can lift 1800 and have 2000 in ballast. At times more ballast would be better. These are anchored by the rear wheels so you must have enough to keep them on the ground!
I don't think I had quite enough ballast either. It had been fine up till then though. Also a good point about a rollover on "flat" ground. You never know when you might hit s soft spot, rut, rock, groundhog hole etc. I handy been using ROPS & belt when mowing but may start. As to relying on a park brake I had set it last week and was in front of, behind another tractor when it popped & released. It's nose was sloped down into the barn and had been set about 5 min when it released. More ballast is on my next agenda. image-1950181969.jpg
Also as I look at the pic, my bucket wasn't low enough either. Crap!
/ ROPS & Seatbelts WORK!! #16
Yeah, look at that, bucket way too high in that last pic. That is not a height to use for moving around. The other thing is that if that large rock/concrete in the rear scoop was meant to be ballast, it's movable and can shift. Could actually become a liability, as it could shift sideways on you.
Yea, I see that now. I was in the process of lowering bucket, but should have before I moved and hit the rut :(
I did have the boulder strapped in and tilted up with top link.
I can see now both were bad ideas
/ ROPS & Seatbelts WORK!! #19
Thank you for posting... it's visual reminders that make for lasting impressions.
The one time I got sideways it happened so fast... in slow motion... there was nothing I could do.
/ ROPS & Seatbelts WORK!! #20
I think you had too much weight in the bucket to begin with. When the tractor bounced rear wheels lifted from ground and the tractor rotated on front axle pivot. Since the pivot is below center of gravity (your loader bucket was also likely above the CG) the CG shifted left plus the momentum of the rotation flipped the tractor on its side.
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2006 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
2021 NM 2HD-18...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
