ROPS need help
/ ROPS need help #21
Danc,
I'm sure you will be happy with the foldable ROPS. I have a B7610HST with a Woods BH6500 hoe with the foldable ROPS set up and never hit my head.
I grab on to the ROPS when I jump from the front operating seat into the back on the seat for the hoe. I just step on the rear tire grab on the ROPS and swing myself into the back.
Good luck . . .
/ ROPS need help #23
Hellos all another lurker finally in the mix. Been reading about the BX23 versus BX2230 and the question of different axles etc. From the Kubota parts book I have found the following: for the BX23 and the BX 2230 the main frame has the same part number, the transmission case has the same part number and the rear axles have the same part number. There are additional parts on the BX23 for the subframe and that also changes the rear fender brackets. Another item that has the same part number is the top link bracket, so the ROPS will probably fit between the two models . That is if you could afford to buy it.
Just thought I would research this since I have the Woods BH on my 2230 - have had much chance to use it though - work gets in the way. Fortunately I am vertically challenged (short) so with the standard ROPS on the 2230 I still have reasonable clearance.
Elis G
/ ROPS need help #24
I have a B2710 w/BH and rigid ROPS. I called my local dealer and he said the only reason they came out with a foldable ROPS was so you could get your rig into a garage. Said your good to go whether you have a rigid or foldable ROPS?!?!
/ ROPS need help #26
The smaller ROPS on the 2230 is the only real PITA
It's more than a PITA .It's a downright dangerous safety risk.
Since to short a ROPS is dangerous on a B tractor it is also just as dangerous on a BX .
/ ROPS need help #27
That's what the dealer told me and I would think these guys know what their talking about. You know, there ARE alot of old wives tales out there.....
/ ROPS need help #28
</font><font color="blue" class="small">( Hellos all another lurker finally in the mix. Been reading about the BX23 versus BX2230 and the question of different axles etc. From the Kubota parts book I have found the following: for the BX23 and the BX 2230 the main frame has the same part number, the transmission case has the same part number and the rear axles have the same part number. There are additional parts on the BX23 for the subframe and that also changes the rear fender brackets. Another item that has the same part number is the top link bracket, so the ROPS will probably fit between the two models . That is if you could afford to buy it.
<font color="red"> 1 * </font> I still have reasonable clearance.
Elis G )</font>
<font color="red">1* </font> Comfort is not the main issue but safety is !!!
/ ROPS need help #29
</font><font color="blue" class="small">( I have a B2710 w/BH and rigid ROPS. I called my local dealer and he said the only reason they came out with a foldable ROPS was so you could get your rig into a garage. Said your good to go whether you have a rigid or foldable ROPS?!?! )</font>
My dealer says just the opposite.
/ ROPS need help #30
</font><font color="blue" class="small">( That's what the dealer told me and I would think these guys know what their talking about. )</font>
My Dealer says just the opposite - so much for the assumption that they know what they are talking about.
Obviously one or the other of these dealers don't know what he's talking about.
/ ROPS need help #31
</font><font color="blue" class="small">( I have a B2710 w/BH and rigid ROPS. I called my local dealer and he said the only reason they came out with a foldable ROPS was so you could get your rig into a garage. Said your're good to go whether you have a rigid or foldable ROPS?!?! )</font>
If you're good to go with a short ROPS then why did the original posters dealer replace his short rops with a taller one for him free of charge.
/ ROPS need help #32
Beats me. Maybe some dealers make money selling things to people that people don't need.
/ ROPS need help
If I may reply to this one,
It's clearly written in the Kubota B4672 Book that if there is less than 40 inches between the top bar of the ROPS and the oprator seat DO NOT USE THE BACKHOE.
The Rigid ROPS only gives about 32-33 inches of clearance while the foldable ROPS has about 9 inches more according to Kubota documentation.
So that is the only reason why the dealer accepted to replace the ROPS free of charge because we have laws up here in Quebec that could void the contract if the dealer sells a product that is not safe according to the manufacturer..... in other terms he had no choice.
Dan
/ ROPS need help #34
</font><font color="blue" class="small">( Beats me. Maybe some dealers make money selling things to people that people don't need them. )</font>
How did the original posters dealer make money selling him something he didn't need by exchanging the fixed ROPS with a foldable one for him at no additional cost ???
/ ROPS need help #35
</font><font color="blue" class="small">( If I may reply to this one,
Dan )</font>
``````` <font color="red"> ~~~ </font> ```````````
In other words one is not good good to go with a BH on a tractor equipped with a Short ROPS ! ! !
/ ROPS need help #37
Thanks, Bill, I appreciate it. I tried to find it on TBN and on Carver's website and obviously didn't know what I was doing 'cause I didn't find it. /forums/images/graemlins/blush.gif I think that's as good an explanation as you'll find as to the reasons for the folding ROPS being required with a 3-point hitch backhoe.
/ ROPS need help #38
My bad, I misread the post. Dealer replaced ROPS for free -ok!
However, and I'm not trying to start something here, but comments associated with the two links are NOT from Kubota.
/ ROPS need help #39
</font><font color="blue" class="small">( comments associated with the two links are NOT from Kubota. )</font>
I think you're right, but they do apply to Kubota, also. For just one example, read this page. My dealer also told me years ago that the folding ROPS is required with the 3-point backhoes.
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
Bobcat SC72 (A64127)
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
Fork Extensions (A65640)
Fork Extensions...
2022 EZ-GO ELITE...
