ROPS Folding
/ ROPS Folding #11
Can you post a picture? The last L2501 I looked at had the same pins for the ROPS as my B2620.
/ ROPS Folding
My B2650 arrived yesterday and they are only pins holding the hinge. That makes my job easier.
/ ROPS Folding #13
Simple pins are as functional as the OEM threaded ones if you can put up with the rattle.
I have used "O" rings on the pin, to take up the slop.
If you have to push the pin a little, to get the retaining clip on, it will be tight enough that it won't rattle.
/ ROPS Folding #14
Any ideas as to why Kubota doesn't choose to standardize on either pins or bolts across models?
Steve
/ ROPS Folding #15
Not to rub it in, but I'm so glad my Bx2660 ROPS doesn't fold and clears my garage door by an inch. I know it's always up and doing its job. And the tree branches in the way get removed soon after they are in the way.
/ ROPS Folding #16
I just ground the threads down on my 'bolts' and use the same cotter pin. No need to buy something new.
/ ROPS Folding #19
I'm always concerned I will forget to fold down the ROPS and tear up the garage and ROPS. I leave it folded down if I am doing some routine task on flat ground.
John Deere S350 (A60462)
John Deere S350...
2000 REITNOUER ALUMINUM FLATBED TRAILER (A60736)
2000 REITNOUER...
AGT Industrial M-DGR (A60463)
AGT Industrial...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2023 Kubota L2501 (A60462)
2023 Kubota L2501...
