Grapple Root Rake Grapple stand or hanger when not in use?
   / Root Rake Grapple stand or hanger when not in use? #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
So I have a wicked root rake grapple from EA and when I’m not using it, I’m not sure the best way to store it is. Right now, I have it lying face down on the ground in a pole barn. I have set it leaning up against trees and also against a hillside in the past. The issue I have with leaning it against something is it flops over easily if I don’t lean it enough. The grapple I have does not have a stand. It’s one of the lighter ones for compact tractors from EA. I really like it. I think it weighs about 240 pounds. I’m thinking I could add a couple beefy hooks to one of the lower rafters in the pole
Barn and just hang it there. I’m also thinking it would be best to have the cylinders all the way into the ram so as to not get pitted and damaged over time. My grapple, when extended, the cylinders are back inside the ram. I’d be interested in your thoughts on this? I’ll post some pictures later today. Thanks! IMG_8459.JPGIMG_8456.JPG
   / Root Rake Grapple stand or hanger when not in use? #2
Well - I got my Land Pride grapple six years ago. I've never had occasion to take it off. My grapple weighs 820#. Not something you are going to "horse around" to reconnect. Having your grapple in a "position" for easy reconnect might be important. It's such low humidity here - I've NEVER had problems with the rusting. But if you do - then extend the grapple and have the cylinders back inside.
I would set your grapple on a pallet and rope it up to the rafters. Just to keep it in an upright position. No need to "hang" it and make the rafter take the full weight.
   / Root Rake Grapple stand or hanger when not in use? #3
When you set it down, it wants to tip back or forward?
   / Root Rake Grapple stand or hanger when not in use? #4
I have the same issue. For the few occasions I need to use my bucket, it makes me dread taking off the grapple because I don't have a good stand to put it on. The last two times, I have pulled up to a hill side and pushed the bottom into the hill, and then leaned the top over with it open. Wedging it in the dirt kept it from moving and when i was ready I was able to pull right back up to it and hook up. This is definitely not a long term storage solution, just used this for a few hours and then I hooked back up to the grapple.
Maybe this winter I will look to see what scrap wood I have around and see what I can bolt together for a stand.
   / Root Rake Grapple stand or hanger when not in use? #5
First with out pictures, I am making an assumption that with your cylinder rods inside the cylinder the grapple is as open as possible.
Can you uncurl (dump) where the grapple rest on the points of the top and bottom portions and unhook from it in this position?
You may still wish to use the pallet concept to keep it off the ground a bit.
If you can not unhook in the above described position, then I suggest a pallet for a base for the grapple to sit on, add supports for which direction lean allows best access to hook and unhook it and let it lean that direction for the amount you determine with the supports you build onto the pallet.
   / Root Rake Grapple stand or hanger when not in use? #6
Usually the cylinder rods are hard chrome plated and will withstand decades of exposure without pitting or rusting.
I would design a folding kickstand for the grapple like the ones on the Land Pride grapples. My Precision Mfg unit has fixed, welded-on parking stands.
   / Root Rake Grapple stand or hanger when not in use? #7
Storing open grapple, I think gravity would pressurize one of the hoses. My grapple has a parking stand, if stored on multiple pallets or a sturdy stand/shelf it's easier to connect if SSQA connector is above tractor hood line. Requires a sturdy stand/shelf
   / Root Rake Grapple stand or hanger when not in use? #8
I use the HF dollies but mine has a flat bottom.
EA was on my short list when I was researching. IIRC at least some models had an optional, parking stand but I want to store mine inside, and with limited space a dolly is essential.
   / Root Rake Grapple stand or hanger when not in use? #9
^^^^^ EA has instructions on the website for this, open it all the way, then tilt it down and rest it wide open on the top and bottom tines. Like you said, the pistons will also be fully retracted and protected inside the cylinders.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
