roosa injector pump
/ roosa injector pump #1
ricks1
have a case dozer with the roosa pump the gasket on the bottom where there is a check ball and a cap screw. Can I get just that gasket? that is only place it drips and looks like it dont have any type of adjustment just the ball
/ roosa injector pump #2
thanks will try the sites, one thing about CASE is if you dont let them do it they dont help you with anything .
I have the ROOSA info if that would help. I dont see reason to pull pump as it is only a small gasket/ seal at bottom.
/ roosa injector pump #4
Give these guys a call. I think you'll probably be able to get the correct seal and advice from them for a very reasonable price.
darrl
there wasnt a number attached to you mail rick
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
CASE INTERNATIONAL 5100 END WHEEL GRAIN DRILL (A63291)
CASE INTERNATIONAL...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
