Rookie Grapple Mistake
/ Rookie Grapple Mistake #1
WRX
Cub Cadet 8354SS
I recently got a new NS with a grapple. It came from the dealer with the grapple installed. I'm using the rear aux remote hydraulic lines to run this grapple, rather than a real third function setup. I haven't taken the grapple off since I got the tractor. I was moving a bunch of downed tree limbs the other day, and noticed that I was pulling back on the lever to open the grapple and pushing to close it, which is opposite of the way it moves. It seemed counter intuitive, so I figured I would just swap the connections to effectively reverse the way the lever had been working. Problem was, I couldn't reconnect the fittings at all. After a few minutes online, I realized my mistake. I had failed to bleed off the pressure on the lines in the grapple and the balls on the fittings would not compress and allow reconnection. I finally had to get a couple of wrenches and open a line, making a mess of spilled hydraulic fluid, to allow reconnection. All is well now, and I'll try not to make that rookie mistake again. I see online that there are tools that allow this pressure release, but they are pricey. If I took the grapple on and off a lot, it might be worth it, but for now, I'll just pay attention. Apparently this happens also if your grapple sits in the sun before you connect it.
/ Rookie Grapple Mistake #2
You did it the hard way. Simply shut the tractor off. Wiggle the remote lever that you are hooked into a few times stop-to-stop. (Once back and forth probably does it)..anyway, just flop the lever back and forth a bit, voila! Pressure released/equalized. Hook-up as usual..then restart tractor.
/ Rookie Grapple Mistake #3
You won't make that mistake again. :D
/ Rookie Grapple Mistake #4
Mine has to have key on to release the pressure on 3rd function
/ Rookie Grapple Mistake #5
I have a nylon rod - 6" long/1/2" in diameter. Put rod on the ball - gentle hit on rod with hammer. Wahlaa - pressure released. If you want to be really "up town" - cover the entire operation with a shop rag. Catch any oil spray.
/ Rookie Grapple Mistake #6
Wrap a rag around it first.
/ Rookie Grapple Mistake #7
Lessons well learned, I have a whole book full of them.:unsure:
/ Rookie Grapple Mistake #8
Always wear gloves and eye protection when working around hydraulics, high pressure water/oil any fluid can be dangerous if it pierces your skin, now that I've scared the poop outta ya have fun with the Grapple!
/ Rookie Grapple Mistake #9
Another situation where pressure can keep you from making the hydraulic connections is when picking up the grapple after having a different attachment on the loader.
My grapple does not have any features to hold it up when I remove it from the loader, so I open it up halfway and set it on the tips of the grapple. When I come to mount it back on later, I have to remember to make the hydraulic connections before I rotate the grapple upright. Otherwise, the weight of the front of the grapple will hang against the cylinder pistons and build up pressure in one of the hoses.
If I can rotate the grapple on the loader such that the front of the grapple hangs freely, the hoses can then be connected easily. If I can't do that, I prop up the front of the grapple with a stick.
At any rate, I try to remember to make the hydraulic connections before I pick up the grapple.
Dave
/ Rookie Grapple Mistake #10
good lesson. one also gets very familiar with this situation when running hydraulic equipment at different elevations.
/ Rookie Grapple Mistake #11
I was using my grapple the other day in the 50's and sunny. I took it off to put my tree grabber on. I made the mistake of connecting the grapple lines together to keep out contamination. between the sun and fluctuating temps it was a bit of a fight to break that apart about two hours later. Then I had to tap the fittings to relive more pressure to reconnect the grapple to the tractor.
I definitely wear good gloves and eye protection when doing all tractor chores. I finally bought a good pair of clear eye protection glasses, no correction, for low light work.
/ Rookie Grapple Mistake #13
OP's comment about pressure change from sitting in the sun is apt. If it is cold when I park my grapple, but warm when I want to reconnect, I have a problem. When I first hook up in spring (after the grapple has sat disconnected all winter) I sometimes rush out first thing in the morning to get it hooked up before pressure builds in the lines.
/ Rookie Grapple Mistake #14
For those with hoses from the rear remotes to the FEL, if you change out your equipment with hydraulic connection...and only have one set of remotes...you might want to somehow label the hoses so you get them hooked up the same way each time. I have flat-face couplers on my grapple, so they are paired male/female, female/male, but the plugs for the remotes are both the same, so can be switched inadvertently; I hate it when the grapple (or snowblower chute) operation is reverse of what I expect.
/ Rookie Grapple Mistake #15
I use a black zip tie on the right side hose coupler.
That's a good idea. I haven't had the grapple off my machine yet but I'm nearing the end of my tree work for this season.
/ Rookie Grapple Mistake #17
Observe the hammer and wrench technique I use to solve this very problem starting just before the two-minute mark.
/ Rookie Grapple Mistake #18
I did the same thing the first time and had a heck of time re-attaching the grapple. Learned to always relieve the pressure. On mine, I have to have the key on but tractor not running.
/ Rookie Grapple Mistake #20
I have a dab of red paint on one line and green on the other. Same with the lines
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
