Roof Mold
/ Roof Mold #1
Dennisfly
Lake Anna, Virginia and Alleghany County, VA
John Deere 4410
Many houses in my area (Virginia where it is humid) with Asphault/fiberglass shingles develop roof mold stains. My house is seven years old and hasn't developed them yet, but I think they are really ugly and would like to avoid them or remove them should they occurr.
I know they make shingles that are supposed to be resistant but I don't know if I have those or not (probably not). They also sell some kind of cleaner in Lowe's which I imagine is bleach based.
The first picture below shows a typical stain and the second shows a roof that has been cleaned and has a spotty scrubbed apearance that is not very good.
Aside from keeping the trees back does anyone know how to avoid or control this or have any experience with the cleaners?
/ Roof Mold #3
The only way to prevent it is to keep the trees away from the home and allow sunshine and air circulation to prevent moss and algae growth. The second pic with the uneven colors looks like someone took a power washer to the roof and removed the colored granules. This is usually caused by the pressure washer at too high a setting. The cleaner should be applied with a garden sprayer to kill the algae and then washed off with water. If done correctly you should not see a color variation on the roof. Good luck if you are gonna DIY or hire a pro.
/ Roof Mold #4
I can't remember the name but I got a cleaner from a roofing company and it cleaned it perfectly with very little effort. I just used a garden hose to wash it off, not a pressure washer. I've heard that bleach will also work, just not as easily.
As far as prevention, look into zinc strips.
/ Roof Mold #5
Pressure washing will get rid of the big stuff either before or after treatment with a commercial product.
A heavy copper wire on the ridge (both sides) will keep moss from forming. The exposed wire creates small amounts of Copper Sulfate that prevent fungus from growing.
/ Roof Mold
Thanks for the info guys. I think I'll do nothing until the first signs of it developing (hopefully that will be never) and then call a professional to do it. A steep pitch, not walkable without a harness, and to far above the ground for me to even think about it.
/ Roof Mold #7
Too late for this, but they make algae resistant shingles that have a small amount of zinc in the granules. I have heard that you can put zinc stips near the ridge of the roof and rainwater will spread enough zinc "runoff" over your roof to prevent algae (mold is really algae). Might want to research it some. Don't use high pressure to remove it if it shows up, it will also remove your granules, which are there to prevent UV degradation. Good Luck.
/ Roof Mold #8
They make an product just for what you describe. I personally used it on my shed that had a carpet growth on north side. It is an extreme alkaloid (oppasite scale of acid) and you just spray it on. I bought mine at Sam's Club.:thumbsup:
Welcome to Wet & Forget
/ Roof Mold #9
I got some wet and forget, trouble is I bought and forgot. :laughing: Still have it somewhere. I have AR shingles, they still have the mildew on them. Mine are 30 yr singles, on for 15 yrs and they are looking bad. Will probably replace in a couple years just due to the looks.
/ Roof Mold #10
Last week, a metal roofing guy told me that newer shingles use limestone in the mix to meet EPA madated lower petroleum levels in their products. He said that the limestone provides the base for mold to grow both on top of and under the shigles.
He was a saleman pushing his products, but what he said does explain why an industry has recently materialized to address shingle cleaning.
After talking to him I loooked up some shingle warranties and saw 40 year and lifetime warranty shingles that had only 10 and 15 year warranties against mold growth.
Has anyone else heard this?
/ Roof Mold #11
Don't know that they make any good asphault shingles any more? All junk.
--->Paul
/ Roof Mold #12
A roofing contractor told me that several years ago. He didn't say it was an EPA mandate, but that they have replaced a lot of the tar in the shingles.
I did see wet and forget in Costco today.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
