Nov 1, 2013 / ronnie tractor #1 R ronkaywilliams New member Joined Nov 1, 2013 Messages 3 Location bumpus mills Tn. Tractor 404 foton My 404 foton tractor sat for two years.I replaced battery & cleaned bowel system put in new fuel. But cannot get it to the injectors need HELP
Nov 1, 2013 / ronnie tractor #2 sd455dan Super Member Joined Oct 23, 2012 Messages 6,821 Location North Idaho Tractor Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold Have you tried to bleed the injector pump, by loosening a bleed screw and pumped the hand operated plunger pump?? Made sure the fuel supply valve is open??
Nov 13, 2013 / ronnie tractor Thread Starter #3 OP R ronkaywilliams New member Joined Nov 1, 2013 Messages 3 Location bumpus mills Tn. Tractor 404 foton Thanks I have don't what you said and it worked
Nov 13, 2013 / ronnie tractor #4 sd455dan Super Member Joined Oct 23, 2012 Messages 6,821 Location North Idaho Tractor Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold So the tractor is up and running??
