Rolling and Arresting Floor Mounted Drill Press Base.
   / Rolling and Arresting Floor Mounted Drill Press Base. #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
Has anyone seem such a thing?
I have very little room in my shop and have recently developed a little alcove perfect for my floor mounted drill press to reside. But no room to tilt it and walk it out, when I wish to use it. Which is OFTEN!
Does anyone make a base with wheels that lower and raise? Using compressed air would be great.
Just thinking, would an air cusion work? Basically a hovercraft!
   / Rolling and Arresting Floor Mounted Drill Press Base. #2
How about just installing it on a base with small casters? That's how I move my generator around.. Bought it at tractor supply for $20..
Not great for something that (in use) has to be stable and solid AND is top heavy!
   / Rolling and Arresting Floor Mounted Drill Press Base. #4
Yeah, not for something that top heavy.
Can't help you OP, mine is bolted to the concrete floor.
   / Rolling and Arresting Floor Mounted Drill Press Base. #5
Ya didn't think of the weight on top..
I would kind of like to try the air cusion, just don't know how big to make it. I don't really like the idea of blowing dust around though.
   / Rolling and Arresting Floor Mounted Drill Press Base. #7
Just a quick search.. Have no idea if they work well or not..
Curious if there is anything special to the last one. I realize that I am limited to parking space in my little alcove. I can't go much bigger than the original base.
Castors often have levers as brakes, but are there none with levers to raise and lower them?
   / Rolling and Arresting Floor Mounted Drill Press Base. #9
Looks like it has fixed wheels in the back and a caster that flips up and down in the front. Then the front corners have rubber "feet" so they don't move.
Aaron Z
VERY interesting. That could be easy to do. I don't know how they activate their front castor but a jack type lever could easily accomplish that. Could even put a D handle on it, pull it forward lowering the single castor and pull the thing out.
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2011 JOHN DEERE 544K WHEEL LOADER (A52705)
2011 JOHN DEERE...
2013 Ford F150 4X4 Pickup Truck (A55788)
2013 Ford F150 4X4...
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
