Roller Stator Shaft Dimentions
   / Roller Stator Shaft Dimentions #1
blake in spokane
Trying to identify tapered shaft dimentions - Rollor Stator hyd. motor. With dial calipers aprox. 1-3/32 dia. at the small end, aprox 1-1/2 tapper per ft. With taps as thread gages, I get an extra fine thread like 22-24 threads per inch ? I'm looking to clarify dimentions to have a hub machined & maybe a castle nut. 5/16 key. Thank you to thoese who respond
   / Roller Stator Shaft Dimentions #2
Check out page 10, illustration #22 here for the White Roller Stator standard 1 1/4" tapered shaft dimensions:
http://www.whitedriveproducts.com/pdf/catalog/2008/CEcatalog.pdf
Those motors, (and motors from other manufacturers as well), are very popular in drive wheel applications on things like scissor lifts, concrete buggies, commercial mowers, etc. 4, 5, and 6 bolt hubs are readily available as a bolt-on for the tapered shaft motors.
Here's a 4 bolt hub on eBay:
4 BOLT WHEEL HUB 1-1/4" TAPERED BORE 1-3161 | eBay
Thanks Brokenot, It goes on a floor polisher. Was I right on the taper? 1-1/2 per ft. We still need to identify the thread or will White know what it is?
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
